Old 12-29-2011, 10:38 PM
FantomMfg's Avatar
FantomMfg is on a distinguished road
G540 Spindle Control for X2 Cnc mini mill problem
I have tried to hook up the G540 vfd to my new x2 mill motor control that i purchased from Surplus Center. I used pminmo.com G540 VFD directions but this did not work. I talked to tech. support at Gecko and they informed me i needed to add an independent power source 10 volts to pos 9 and pos 7. I did this and was able to get 0 to 10v increase/ decrease, m3 and m5 shutdown through mach 3 control on pos 8 out. The G540 was not connected to the motor control just a Volt meter. Once hooked to the new motor control i could not get it to control the board? The board has a 5k pot and works fine with the pot. If i disconnect the pot the spindle ramps up to full rpm? Anyone have there x2 running spindle control from the g540 and care to share their wiring diagram?
ID:	149038   Click image for larger version
Name:	Motor wiring diagram.jpg‎
ID:	149039   Click image for larger version
Old 12-30-2011, 07:46 PM
FantomMfg's Avatar
Thumbs up Mystery Solved
Thanks to the kind gentlemen-Arturo Duncan for his assistance in solving the G540 vfd mystery. The wiring format below works excellent. M3, M5, spindle increase/decrease, and spindle shutdown on E-stop. I used the Xml file from Pminmo.com/misc/540BVFD. This file worked far better than the Gecko Site Xml file.I used a 5 volt cell phone power supply for the vfd 10 volt pin, positive straight to the Gecko and ground spliced with wire coming from the vfd ground to connection S1. Seems to work fine. X2 Spindle control via the G540 is up and working; Cool!
This is how it goes:
SC G540 Function
S1 VFD-GND P1 / Common for the analog signal.
S2 VFD-OUTPUT P2 / Analog signal or wiper
S3 Not used P3 / Reference voltage.
Arturo Duncan
:: CNC4PC :: iNtRo
G540 spindle control. krakenatwork Gecko Drives 0 03-31-2011 09:11 PM
Need Help!- G540 spindle control problem rewster Benchtop Machines 8 12-18-2010 05:14 PM
Is it possible? (G540 spindle control) fretsman Gecko Drives 6 10-13-2009 06:27 PM
Spindle Control Through G540 john1285 Gecko Drives 1 09-30-2009 10:26 AM
mini mill dc spindle speed control (newbe) chrisplashek Benchtop Machines 10 06-19-2007 10:34 PM
