Old 12-28-2011, 07:43 AM
kalimero is on a distinguished road
Resistor question for gecko 202
I have ncpod board gecko202 drivers , power supply 24v/6A and motors;
Model # 24H290-35-8B
Bipolar Serial specs
- 2.5 A/phase
- 2.4 ohms/phase resistance
- 8.4 mH/phase inductance
Bipolar Parallel specs
- 5.0 A/phase
- 0.6 ohms/phase resistance
- 2.1 mH/phase inductance
I like to use bipolar parallel setting but I don't know what resistor I need to buy.
Thanks for any help.
Old 12-28-2011, 10:14 PM
doorknob's Avatar
doorknob is on a distinguished road
According to Support, the proper resistance value for a 5A phase current would be 117.5K ohms.
Old 12-28-2011, 10:55 PM
Thanks. Two more question:
If I use "Bipolar Serial " is that mean that I can use this setting "2.5A – 26.1K".,
Because my power supply is 24v/6A this bipolar serial setting is better?
Old 12-28-2011, 11:41 PM
doorknob's Avatar
How many motors do you plan to drive with that power supply? Are you concerned that the power supply will not be able to supply sufficient current?
It is probably not a good idea to wire that motor for bipolar series. As it is, your power supply voltage is somewhat low for that motor when it is hooked up as bipolar parallel (the recommended voltage in that configuration would be about 46 volts if I have done the math correctly).
With a bipolar series hookup, even though the current requirement would be lower, the recommended voltage would be closer to 90 volts (but I believe that the driver is only rated for a maximum of 80 volts). Using only 24 volts in that configuration would probably lead to reduced torque when you are trying to run at higher speeds (or you may not be able to run at higher speeds).
You might want to consider getting a power supply that is more closely matched to your motor's specs.
current set resistor question m8kingit Gecko Drives 8 03-20-2009 08:00 AM
Gecko 540 and Resistor question SpeedsCustom Gecko Drives 7 11-30-2008 09:39 AM
gecko resistor need verification dertsap Gecko Drives 9 08-15-2006 12:31 AM
resistor question plast744 General Electronics Discussion 8 07-10-2005 02:20 PM
Resistor for gecko bgolash Gecko Drives 1 12-13-2004 01:07 AM
