Old 12-10-2011, 03:59 PM
bjmrtn is on a distinguished road
Random g540 Faults
Is there any way to get more information about why the Gecko g540 is going into fault? This recently started happening after a few months of use. I am using EMC2 Linux CNC software. The program will be running along fine and then all of a sudden the g540 goes into fault, random times, no apparent reason. The EMC2 software appears to keep going along as if nothing has happened. Any EMC2 users out there? Does EMC2 do an logging at all? I haven't been able to find any.
Old 12-10-2011, 04:13 PM
ger21's Avatar
DO you have a heatsink or fan on the G540? Is it getting hot?
Old 12-10-2011, 04:19 PM
No heatsink but my work space is only 55 maybe 60 degrees F. The g540 feels only warm to the touch. I can hold my hand on it. One thing I have recently done is added a wifi card to the computer. I am going to disable it and see if the problem persists. I don't know why that would impact the system like this but it is worth a shot.
Old 12-18-2011, 08:09 AM
fragger6662000's Avatar
fragger6662000 is on a distinguished road
did that work?
if you move the parallel cable does that cause it to error?
Old 12-18-2011, 08:16 AM
No, it didn't. I ended up replacing the computer and got mach3 instead. It has been fine since. Thanks for the help tho!
Tags
emc2, fault, g540
HELP, mach throws up random ESTOP mid program. Gecko G540 dougie329 Mach Software (ArtSoft software) 3 12-04-2011 12:35 PM
g540 Faults with more than 2 motors hooked up? R08ert209cali Gecko Drives 1 11-28-2011 01:26 PM
G540 Random fault light on power up mchm66 Gecko Drives 6 09-05-2011 03:51 AM
random stalling g540 ihavenofish Gecko Drives 8 05-04-2009 12:49 PM
TM1 faults f1jdm Haas Mills 3 01-10-2008 05:22 PM
