Old 11-15-2011, 04:13 PM
lcvette is on a distinguished road
torch relay ?'s
Hello all,
I have recently upgraded from a toshiba board to the gecko G540 and have everything for the motors and gantry on the way and understand that fine but i am not quite sure what relay i will need to fire the plasma torch. the torch uses a simple switch to close a circuit but do i power the relay with the 48v power supply or is there a low voltage source on the gecko drive better suited to fire the torch relay. what size relays would you recommend in either scenario and if you have a source to purchase the correct relay from that would be greatly appreciated!
Thanks in advance!
Chris
Thanks!
Powermax 85 question regarding mach3+bob+relay+torch start hayaome Hypertherm Plasma 1 10-19-2011 10:27 PM
Need Help!- 24Vdc Solid State Relay not the same as mechanical relay?? cjchands General Electronics Discussion 7 11-10-2010 12:40 AM
Using a solid state relay as a main stop relay garagefela General Electronics Discussion 4 02-26-2010 04:27 PM
using a relay to activate a plasma torch (mach3) Delanoman Mach Plasma / Laser 5 11-03-2009 12:14 PM
torch relay problem dgalaxy General Electronics Discussion 6 07-16-2006 09:03 AM
