Hi, I have G203V Geckodrive's and my motors needs 6.1 and 4.3 amps to run, in the owner's manual it give me 282K for 6 amps and 62.67k for 4 amps. If I do the maths properly i think that the required resistor would be 286.7 and 67.37 Kohm. First I would like to know if my maths are correct and if so what are the colors coding for the resistors. Thank you |
| Hi the resistor values given in the manual are the nearest 5% resistors to set the current from 1A to 7A ,in 1/2 amp steps for 6.1A R in K ohm = (47 x 6.1)/( 7-6.1) = 286.7/0.9 = 318.56 ohms for 4.3A R = (47 x 4.3)/ (7-4.3) = 202.1/2.7 = 69.69 ohms the colour code on the resistors will depend on the series the resistors are from 5% resistors fom E24 will have 3 bands indicating the value 2 for the fist 2 digits and then 1 for the multiplier (plus gold for 5% tolerance) eg 10K = brown black orange gold ( 1 ,0, x 1000 +or -5%) but a 1% resistor can be 4 or 5 bands to indicate the value http://www.radio-electronics.com/inf...ding-chart.php Electronics 2000 | Preferred Resistor Values Resistor E Series - E3, E6, E12, E24, E48, E96 Tables :: Radio-Electronics.Com http://samengstrom.com/24614782/en/r...or_Color_Codes http://samengstrom.com/15924820/en/r...or_Color_Codes John Last edited by john_100; 11-12-2011 at 03:55 PM. |
| Hi If I'm understanding this, I would need a 318.56 k ohm for the 6.1 Amp and a 69.69 K ohm for the 4.3 Amp, if so can I round it out at 320 and 70. I think that the four band 5% resistors are the most available around here Thank you for your help |
| Hi, yes in theory thats the resistors you want but in practice have to compromise and use the E12 range of values for example use a 68K ohm resistor for the 4.3A motor or 68K + 10K is series if you use two resistors and a 270 K ohm for the 6.1 A motor if you use a single resistor or a 270K and a 47K resistor in series if you use two resistors you could use a 330K resistor if you decide to go just over 6.1A John |
| Current Set Resistor? | Fastest1 | Gecko Drives | 4 | 08-27-2011 07:12 AM |
| Need Help!- Bleeder resistor | gaga2410 | General Electronics Discussion | 2 | 06-22-2009 12:31 AM |
| bleed resistor | bobleecnc | General Electronics Discussion | 11 | 04-30-2007 06:56 PM |
| resistor question | plast744 | General Electronics Discussion | 8 | 07-10-2005 02:20 PM |
| amp set resistor | Don C | Gecko Drives | 6 | 02-10-2005 02:41 PM |
