I have a gecko g540 with new steppers. They are buzzing while idle quite audibly. Also, when jogging the axis and then stopping, sometimes there is a high pitch noise generated. Im wondering if you can propose what may be wrong? Bad driver? Bad motors? |
| That can be quite normal with chopper stepper drives (which the Gecko is one) and motors of a higher inductance. Because of the higher motor inductance the chopping frequency may be low enough to be in the audible range. If you increase the PSU voltage it will increase the chopping frequency. Otherwise you could wire the motors in bipolar half coil instead of bipolar series, that will decrease the inductance but will also likely reduce the torque. Probably the easiest thing to do is just ignore the noise. |
| Ive wired them pipolar parallel already. Its quite loud and Im not even being picky. My old steppers you can hear some noise while idle if you put your ear to it. These ones I could hear from across the room. They are like this even when in stepper power test mode with the charge pump off to the G540, and not plugged into the computer. Whats considered 'high' inductance? Mine are tiny steppers too, under 200Ozin and 2.4mH according to specs. |
| Check your power supply, Put a good 2200 uf Cap close to the drive. What is the motor winding resistance ? Gecko's are usually very quiet. Also the gecko isn't a chopper, its a PWM drive, which are much more silent.
__________________ Manufacturer of CNC routers and Viper Servo Drives www.LarkenCNC.com and www.Viperservo.com |
| The description "high pitch noise" means different things to different people ![]() To me, it describes the stall noise of a stepper. I got this when I didn't use good acceleration values on a new machine. Since you've apparently changed your motors to something weaker than before, this might be worth investigating. |
| The high pitch 'whine' is a more accurate description. Its a short pulse. High pitch. Right at the end during the stopping/deceleraton. Analogy is squeaking sound of metal fork on metal plate. Im trying to identify whether it is bad steppers, bad driver or both. My old steppers and driver are fairly quiet. I recently upgraded and got things setup but these are loud. The resistance of the windings are very low (quickly measured from the DB9 termination using a 2 terminal instead of 4 point kelvin probe as thats what I have at home at the moment), and is less than an ohm around ~0.7ohms (including wire resistance). |
| It's normal for steppers to make much more noise at low RPM due to the increased per-microstep excitation energy (mechanical resonance). So maybe you are hearing a noise during accel and decel, but it is much quieter when at top speed? That would be typical, and does sound like a "squeak". If you run the stepper at a very slow speed (1 motor revolution every 2 seconds) does it make a much louder noise than at high speeds? If you can run each axis at some different speeds and compare how loud the motor is compared to the "bad" noise it may give some clues. |
| I wasnt speaking about noise from the steppers while it was moving at low RPMs. I was speaking of the idle noise as well as the intermittent squeak at then end of movement. Things are not wired incorrectly since they seem to move. Im worried about defective products with faster than normal failure. Keling quite apparently provides no after sales support for their products and stops responding to emails. |
| Steppers for Gecko G540 | orion63 | DIY-CNC Router Table Machines | 25 | 05-24-2011 01:13 PM |
| Gecko G540 - stepper with high Phase Inductance?? | MaxTheModder | Stepper Motors and Drives | 9 | 03-13-2011 12:54 PM |
| Please recommend an E-Stop and home switches for Gecko G540 | CNC Lurker | Gecko Drives | 3 | 12-13-2010 07:45 AM |
| Got a Gecko G540, now which limit switches and E-Stop? | CNC Lurker | DIY-CNC Router Table Machines | 19 | 12-06-2010 03:13 AM |
| New Machine Build- Need steppers for Gecko G540? | The CNC Man | Stepper Motors and Drives | 10 | 02-01-2010 07:08 PM |
