Old 11-06-2011, 03:43 AM
noobCNC is on a distinguished road
Back EMF problem for G540? (manual cranking handwheel)
I dont think I read anywhere on the manual addressing whether or not it is ok to crank the handwheel when everything is plugged in (but power off to the G540).
Is it ok or do you have to unplug everything or maybe short the resistor if it allows easy changing?
Or can you just crank away?
Old 11-07-2011, 08:02 PM
Gold Member
Mariss Freimanis is on a distinguished road
Feel free to crank away. Cranking will be easier if you power-up the G540 and have it in E-Stop (red LED). That way your muscles don't have to run the cranked motor as a generator.
Mariss
G540 Updated Manual CoAMarcus Gecko Drives 4 06-09-2010 01:18 PM
Relay with G540 and a manual switch? 2nd try Fastest1 Gecko Drives 4 02-27-2010 04:22 PM
My Upside down back to front problem Cosha Mach Software (ArtSoft software) 0 03-03-2009 02:32 PM
Problem: Feed back on Screen from Spindle northstarr Haas Mills 2 06-28-2008 09:02 AM
Cranking out part's on Benchtop Mills Ron111 Benchtop Machines 4 06-09-2007 11:39 AM
