Old 10-29-2011, 07:46 PM
Ed Williams is on a distinguished road
G540 cutting size wrong
I am having a problem. I have gecko servos on the rest of my mills so I thought I would try a stepper. On a unit that has the same ball screws that are on my other units. I am using the same code as on the others. I have my steps set to 10160 and the unit will move 49 inches. In mach it says 49 inches. But when I mill a piece it is always .015 smaller. It makes no difference if the piece is 1 inch or 5 inches it is .015 smaller. I have changed the spindle and collect still .015 smaller. Any idea.
Thanks Ed
Old 10-29-2011, 07:53 PM
WoodSpinner's Avatar
WoodSpinner is on a distinguished road
Thanks Ed
repeatable backlash?
Need Help!- G540 doesn´t work. What may be wrong? jaru-eri Gecko Drives 8 10-07-2011 04:14 PM
Need Help!- My parts are coming out the wrong size! bremerr DIY-CNC Router Table Machines 18 09-06-2011 12:50 PM
Need Help!- EMC2 and G540 help needed. Wrong way Homie. pencilneck DIY-CNC Router Table Machines 8 05-12-2011 06:40 AM
Wrong Ballscrew Size? ozzie34231 Linear and Rotary Motion 8 01-04-2008 11:23 AM
Help! Cuts Wrong Size archcasings WoodWorking 7 09-29-2005 06:05 PM
