Old 10-25-2011, 05:56 PM
BanduraMaker is on a distinguished road
Strange behavior with VFD
I'm using a gecko g540 to control a hitachi WJ200 vfd. I'm using the 0-10v signal for speed and output 1 for run control. Everything was working fine but today I came down to machine some parts and unplugged a USB cable connecting the hitachi to the compute, just because i didn't think it necessaryr. When I went to run my program, the spindle didn't start up and I almost wrecked a bit.
I figured it t on accident when I started up pro drive next, hitachi's programming software to see if any settings mysteriously changed on me. When I plugged the USB cable back in, the spindle started up!
I'm thinking this must be a grounding issue because there's no control software running on the pc to run the vfd.
My connections between the gecko are
GND, 10v and signal to pins L, H and O, Output one to smart pin 1.
Any ideas as to what may be wrong?
-Andy
http://banduramaker.blogspot.com
Old 10-29-2011, 07:27 AM
C'mon - no one?
-Andy
Old 11-15-2011, 07:35 AM
PEU's Avatar
PEU PEU is offline
PEU is on a distinguished road
charge pump enabled?
● Distribuidor Syil en Argentina ● "www.syil.com.ar" ●
Old 11-15-2011, 08:00 AM
I fixed it, just forgot to post on this thread.
Turns out that the grounds on the control voltage and the start pins are not shared on either the VFD or the Gecko. When I tied the VFD smart pin ground to the Gecko ground it started working properly.
-Andy
NM-200 - strange behavior? kvom Novakon Systems 1 07-28-2011 06:14 PM
NM-200 - strange behavior? kvom Novakon Systems 3 05-24-2011 08:28 AM
New Machine Build- Strange Behavior. riveracnc Mach Software (ArtSoft software) 2 11-28-2008 06:54 PM
Milltronics strange behavior KBHone Milltronics 1 12-09-2007 05:00 PM
Strange circle behavior, 151B control swarf_rat Bridgeport and Hardinge Mills 11 07-15-2007 09:08 PM
