Old 10-21-2011, 06:21 PM
cristachelu is on a distinguished road
G213V not working
Hello,
I'm new to this forum.
Here is my problem.
I got a Gecko G213V stepper driver 2 days ago.
I built the stepper tester on their website using 7414 inverter and I replaced the resistor with a potentiometer to adjust the pulse frequency.
I tried all microstep, half step, full step combinations with 3 motors
I could not get more than 100-150 rpm no matter how slow I was ramping up the speed.
The 3 motors I tested with were
(1)
Motor Frame size: NEMA 34
Holding Torque: 63 kg.cm / 874 oz.in
6.6V
3A
12mH
2.2 Ohm
(2)
Holding Torque: 48 kg.cm / 665 oz.in
6V
2A
12mH
3 Ohm
(3)
NEMA 23
20 kg.cm / 277 oz.in
3.6V
3A
2.4mH
1.2 Ohm
With the big one (6.3Nm) while adjusting the potentiometer I got the fuse blown.
I replaced the fuse with the original part as per spec and now the green and red led are lit no matter what motor and configuration I'm testing
I have another cheap chinese driver which ran all the motors fine but slow but I cannot make them run again with the G213V
I'm not sure what "undestructable" means on gecko website. I handle it with enough care, didn't shorted any motor or driver output.
Did anybody experienced something similar with this drive?
Jog not working arizonavideo Machines running Mach Software 0 12-26-2010 12:52 AM
G96 not working as it should mbpp G-Code Programing 0 06-14-2009 07:51 AM
G96 Not Working How it Should on T32 mbpp Mazak, Mitsubishi, Mazatrol 0 06-13-2009 08:53 AM
What are you working on? stevehuckss396 I.C. Engines 12 12-05-2008 03:00 PM
Trying to get my x2 CNC working... TheWolf Benchtop Machines 14 03-26-2008 09:27 PM
