Old 10-12-2011, 08:28 AM
MIDDEN300 is on a distinguished road
G540 Z AXIS PROBLEM
i have a gecko g540 on a k2 cnc machine
i am using a vcarve program has lot of z movement all obsolute
the problem i have is the z axis every letter i engrave keeps losing depth
untill it will stop touching part.i recheck my tool offset and it
will be .030-.040 higher than it was set to.i run program 1.0 above part with no
spindle running and get same results.i run z up and down with dial indicator about 50 times
and it repeats every time x y work no problem.
any ideas.
Old 10-12-2011, 11:52 AM
Galtor is on a distinguished road
Tool moving up in holder? Mark the tool or measure the length sticking out. Run the program and measure the length or check your mark.
Old 10-12-2011, 01:21 PM
i have .500 dia. adapter bottomed out in spindle and i have flat ground on
.125 60 deg carbide engraving tool but to eliminate i will check z to main
z gantry before and after running program,i had also check tool for any
chipping did not see any. thanks for reply.
Old 10-13-2011, 06:59 AM
Frederic Gagnon is on a distinguished road
Also check any slack between the leadscrew and the Z stepper. Maybe you have a loose shaft collar there. Try lifting your spindle by hand and you'll see.
Old 10-14-2011, 08:11 AM
could not find any problem i changed my progam to just regular engraving
letters and it worked with no problem.
only thing i can figure is gecko control must loose steps with all the
z movment thier is a small z move on almost every line of the program of 4000
lines for 25 letters.using bobcad to program.only good thing it loses depth.
i ran v carve program again after engraving same problem
Old 10-14-2011, 10:46 AM
ger21's Avatar
Cut your Z acceleration in half and then try it.
Need Help!- g540 problem draxus Gecko Drives 7 07-11-2011 12:35 PM
Problem- Odd Y axis problem with G540 mhackney Gecko Drives 3 07-24-2010 06:56 PM
Need Help!- Problem with G540 hab82 Gecko Drives 4 04-30-2009 04:21 AM
g540 y axis problem meck11 Gecko Drives 3 03-31-2009 02:57 PM
G540 Rev.1 has problem sse4 Gecko Drives 6 02-25-2009 07:48 AM
