Old 10-02-2011, 08:49 PM
daniellyall is on a distinguished road
g540 / superpid / mach3
does anyone now what config to use for the superpid running mach3 through a g540
can get spindle to turn on and off but cannot seem to change the speed of the spindle in mach 3 help please
Old 10-03-2011, 03:15 PM
every thing is configed and wired properly it will do 5000rpm or 30000rpm only
have set pully 4 to 5000 min 30000 max will try changeing to 5000rpm min 10000rpm max a see if it will do 5000 or 10000 if it does work will config pullys 5000min 6000max so on
G540 E-stop and Mach3 Astroguy Gecko Drives 24 02-02-2012 10:10 PM
Need Help!- Setting up X and Y G540/Mach3 ssutton DIY-CNC Router Table Machines 4 03-07-2011 05:46 PM
Need Help!- Help with Mach3 and missing steps G540 tristen0821 DIY-CNC Router Table Machines 23 01-26-2011 07:51 AM
Mach3 + SmoothStepper + G540 = No go CarbonKevin Mach Software (ArtSoft software) 2 11-23-2009 05:09 PM
G540 Mach3 XML File CoAMarcus Gecko Drives 4 11-07-2008 11:38 PM
