Old 10-06-2005, 09:05 AM
Biggermens is on a distinguished road
Small Preoblem
I have a small problem
i have 2 motors that jam while it is running on the bench with no load X and Y
Z is fine i try the X and Y motors on Z G202 and thay run fine i am using G202 and mach 3
my question is
are all the trimpot set the same from factory ??
and will a bad set trimpot do that ???
or are thay defective ??
and is it bad to conecte the motor coils backwards ? A+ to B+ A- to B- ???
my motors are 3.18A i test the curent when the motors turn and i get around 1.2 is that ok ???
Yves
Old 10-06-2005, 09:23 AM
ger21's Avatar
Did you put the current set resistor on the Gecko's to set the current?
Wiring the motors incorrectly can damage the Geckos.
Old 10-06-2005, 10:24 AM
Yap the resistor is set right
Old 10-06-2005, 08:06 PM
trubleshtr is on a distinguished road
Do they jam at high speed or slow? you may have bad bearings that rear their ugly head at high speed ie 1000 RPM++++
menomana
