Old 09-15-2011, 04:40 PM
PEU's Avatar
PEU PEU is offline
PEU is on a distinguished road
Heatsinking G250x, Part 2
After giving it a tought I came up with this idea, it will allow to use G250x pulled out of G540's (we only use 2 for the lathes) like a regular drive, the PCB is single sided so it can be machined or etched easily, the heatsink doubles as a support for the green terminal block, once I gather enough G250x out of g540s I will make a small batch of these and post photos
Pablo
● Distribuidor Syil en Argentina ● "www.syil.com.ar" ●
Old 12-09-2011, 06:23 AM
tumutbound's Avatar
tumutbound is on a distinguished road
Hi Pablo,
Did you ever end up designing/making any of these interface cards?
I've got some cheap Chinese drivers to replace and I have a stack of G250s just ready for such a use.
Regards
Geoff
Old 12-11-2011, 03:32 PM
PEU's Avatar
PEU PEU is offline
Last week I purchased the terminals at digikey because I cannot find them here with 3.5mm pitch, I guess 10 more days to arrive here and then its build time
Pablo
Old 01-31-2012, 04:47 AM
tumutbound's Avatar
Thumbs up Gecko to the rescue
After communications with Gecko, I've been able to buy some G540 mother boards to mount the G250s on. As my G250s have a female socket as does the G540 board, I'll need to use some header pins to connect them.
Thanks Gecko!
Regards
Geoff
Old 02-02-2012, 09:04 PM
Gold Member
Mariss Freimanis is on a distinguished road
Have you considered porting the G250 outputs to Tyco MTA-156 or MTA-100 style connectors? They are IDC (insulation displacement connectors) that are incredibly cheap (<$0.20) and very reliable up to 7A and 5A respectively. They are what you see in your washing machine or other major appliance if you tear it up just to see what's inside.
Mariss
Heatsinking G250x, kapton tape+bare aluminium? PEU Gecko Drives 3 09-14-2011 02:33 PM
Geckos and heatsinking Zeljkoc Gecko Drives 2 11-10-2010 03:47 PM
Newb ? - CAD Part interference & mating part dims pabmartin Mechanical Calculations/Engineering Design 3 11-06-2009 12:18 AM
Heatsinking the HP-UHU H.O UHU Servo Controllers 16 11-02-2009 04:45 PM
Heatsinking Your G540 CoAMarcus Gecko Drives 5 02-24-2009 01:33 PM
