Old 09-11-2011, 11:11 PM
Sunmixed is on a distinguished road
How to prevent excessive voltage to Geckodrive logic inputs?
Well i would like to certainly thank the Geckodrives Motor Control for taking the trouble to inspect my broken drives. Recieved with thanks!
In the invoice I was provided with inspection results, in 3 of the G230V D, it reads "Customer-induced damage by possibly applying excessive voltage on logic inputs was found." But with heartiest condolence, Geckodrive is nice to provide one replacement drive! Thanks again
I would like to certainly understand more about this damage, as I truly have not applied excessive voltage to the step and direction pins. The step, direction and COMMON GROUND pins are purely from the parallel port of the PC.
How may excessive voltage occurs? Are the causes are by high frequency noise, or EMI?
How may one prevent such from happening? Is there a suggested circuit I can construct to prevent such excessive voltage?
"I will not let you regret knowing me."
Back emf, is there a way to prevent? REVCAM_Bob General Electronics Discussion 15 10-29-2011 10:43 AM
Newbie- G540 inputs and outputs voltage Brenck Gecko Drives 0 07-27-2011 09:48 PM
What if and can I prevent it stk2008 DIY-CNC Router Table Machines 5 05-26-2010 02:31 PM
Newbie- Prevent the z axis from cutting the table up JimmyL Work Fixtures and Hold-Down Solutions 12 10-28-2009 03:30 PM
Looking to prevent a future crash. dfrey2@rocheste Haas Lathes 2 02-01-2009 11:05 AM
