Page 2 of 2 FirstFirst 12
Results 13 to 15 of 15
Thread: G540 & VFD
  1. #13
    PEU
    PEU is offline
    Registered PEU's Avatar
    May 2005
    Buenos Aires - Argentina (I like Ribs)
    Quote Originally Posted by Mariss Freimanis View Post
    PEU,
    <i>"It would be great if the G540 could supply the reference voltage derived from the motors supply."</i>
    When the G540 was designed, the VFD section was meant to replace the remote speed control potentiometer. My understanding was most VFD drives have that option. A 5K potentiometer is specified and it has 10VDC across it.
    Thanks for the reply Mariss, after posting this I checked the suggested improvements for the G540 in the thread about that and saw that a 12v 50ma line is being considered as an addition to the current design, that would do too.
    I would suggest adding a few more lines to the user manual, will post about that in the g540 suggestions thread.
    Quote Originally Posted by Al_The_Man View Post
    Mariss, apparently this VFD does not supply +10v for the Pot.
    It can be set for 24vdc pot supply or just analogue input and com.
    See configuration post #1.
    Yes, this VFD does not provide +10, its a 0.75KW single phase input unit not much bigger than a can of soda, amazing what they can do in such a small space.
    Got it working yesterday under mach3 control via the G540, need to add relay for FOR/REV control and tidy up the control panel.
    Thanks guys
    ● Distribuidor Syil en Argentina ● "www.syil.com.ar" ●
  2. #14
    Aug 2008
    PEU,
    Communication will be RS-485 and no, it won't work with Mach3.
    why not?
  3. #15
    Dec 2003
    A plug in has been written for huanyang for USB to RS-485, which is non-ModBus compatible.
    I am hoping to get an idea what is needed for plugin programming, I have the tools, I just need to get up to speed with them.
  1. g540.xml ????????????
    By breathe in forum Open Source CNC Machine Designs
    Last Post: 08-31-2010, 08:24 AM
  2. G540 PWM
    By mikie in forum Gecko Drives
    Last Post: 05-21-2010, 01:50 AM
  3. What can i do with a G540
    By matttargett4 in forum Gecko Drives
    Last Post: 03-04-2010, 11:24 AM
  4. Hot G540
    By jdemille in forum Gecko Drives
    Last Post: 05-08-2009, 01:40 PM
  5. can you... BOB to G540?
    By Fixittt in forum Gecko Drives
    Last Post: 01-28-2009, 07:37 AM
