Old 08-29-2011, 03:40 PM
Flateric is on a distinguished road
Speed controlling my maxon drive with my g540.
Anyways, my question is..
I have from a dental system recovered a very nice Maxon motor driver and matched servo motor that drives a very nice precision spindle.
This is the drive I have..
https://downloads.maxonmotor.com/Kat...uctions_En.pdf
I am curious if I can make use of this drive through my g540, allowing mach3 to control my spindle and it's speed in an ideal world. The 1-q-ec has disable, direction and brake functions as well as a speed input which uses a 0-5v range for determining the desired speed in an analog form. Or a Aux input/output which can control the speed through again a 5v input.
My concern is that the g540 is a 10v output.
Or am I completely misunderstanding my ability to potentially use this as a spindle and control it from my g540?
Thanks very much for your time and input. I very much appreciate it!
Gord
Old 08-30-2011, 08:13 PM
PEU's Avatar
PEU PEU is offline
PEU is on a distinguished road
If you need 0-5V just use a resistor divider, two 1K resistors
Pablo
● Distribuidor Syil en Argentina ● "www.syil.com.ar" ●
Old 08-30-2011, 08:18 PM
You sir are the best!
Thanks for taking the time to consider and answer my question.
I really do appreciate it very much. I think I'll do a little more research and give your idea a try!
Controlling Speed of Bosch 1617 via CNC n1k86 DIY-CNC Router Table Machines 8 07-15-2011 05:02 PM
Newbie- Controlling Router Spindle Start/Stop/Speed AntonCNC General CNC (Mill and Lathe) Control Software (NC) 10 10-17-2009 03:04 PM
Need info on Maxon servo drive MrWild Servo Motors and Drives 2 01-25-2009 12:03 PM
Controlling Variable Frequqncy Drive? KNRO General Electronics Discussion 7 10-31-2008 10:54 PM
controlling spindle speed R.thayer LinuxCNC (formerly EMC2) 4 01-14-2007 11:43 PM
