Old 08-26-2011, 10:48 PM
bel630 is on a distinguished road
g540 complete wiring
hello..
just receive 3 axis kit from keling yesterday..
after study wiring diagram from keling, i can't understand about relay and vfd drive, how many volt power supply i need for relay? what relay and vfd drive actually use for?
my kit come with 3 nema 34 stepper, what kind of resistor to use?
Thanks...
Old 08-27-2011, 04:07 PM
Fastest1 is on a distinguished road
Bel630, are you talking current set resistors for the steppers and the G540? The voltage supply for the relays (coolant, vacuum whatever) is any voltage between 0 & 50vdc if I remember correctly.
Old 08-27-2011, 04:09 PM
What steppers did you get from Keling? Model #?
Old 08-27-2011, 07:17 PM
i'm use NEMA 34 KL34H260-35-4B..
Old 08-27-2011, 08:31 PM
That is a 3.5 amp stepper according to the specs. It might not need a current set resistor at all, but I would confirm it before I went direct.
Old 08-27-2011, 08:38 PM
no need current set resistor? that mean just ignore pin 1 & pin 5?
Old 08-28-2011, 08:59 AM
This was answered by someone else in another thread, they suggested a 3.48k resistor. The max output on any axis with a G540 is 3.5a so I thought maybe it wasnt needed. I think my idea was wrong
Old 08-28-2011, 10:50 AM
john_100's Avatar
john_100 is on a distinguished road
that would be me ! in my reply to:-
http://www.cnczone.com/forums/gecko_...tml#post984412
as I read the info from Gecko the maximum current out is 3.5A
but without the resistor ,the current isn't reduced with the drive idle
from the manual:-
"your motor is rated at 3.5A or above you can safely not use a current set resistor; however, your
G540 will not go into current standby mode which will result in increased motor heating."
John
Old 08-28-2011, 04:56 PM
from the manual:-
John
thanks for your info.. unfortunately 3.48K 1% resistor like hard to find.. can i use below 3.48k?
Old 08-28-2011, 05:15 PM
john_100's Avatar
yes
if you use 3.3k resistors you will have an output of 3.3 A
which is about 95% of the 3.5A maximum
if you need an output closer to 3.5A
either use a 3.3K resistor and a 180 ohm in series
or if you have a number of 3.3K 5% resistors you could select
resistors at the upper limit 3.300K x 1.05 = 3.465K
John
  #11   Ban this user!
Old 08-28-2011, 09:43 PM
yes
John
thanks.. i got an idea now...
  #12   Ban this user!
Old 08-30-2011, 08:07 PM
PEU's Avatar
PEU PEU is offline
PEU is on a distinguished road
Best solution I found to the 3K5 resistor is purchasing 3K9 and 33K resistors and putting them in parallel, it gives you 3.48K pretty close using cheap and readily available regular resistors.
Pablo
● Distribuidor Syil en Argentina ● "www.syil.com.ar" ●
Need Help!- X2 G540 Wiring Question Steoh Benchtop Machines 6 03-01-2011 06:53 PM
G540 wiring diagram for dummies? :) bkboggy Gecko Drives 27 08-28-2010 01:45 PM
Need Help!- Optical home switch wiring to G540 mhackney General Electronics Discussion 3 01-18-2010 07:31 PM
Wiring a G540 into 4 axis Xylotex box justCNCit General Electronics Discussion 1 11-27-2009 05:12 PM
G540 Wiring clamps Gecko Drives 3 07-16-2009 11:41 AM
