Results 1 to 4 of 4
Thread: G540 and Sieg KX1
    Aug 2011
    G540 and Sieg KX1
    Hi all;
    I'm new to CNC; have a controller-less Sieg KX1 and a g540 in the mail.
    2 questions:
    1) spindle - have 3 lines, "gnd", "avi" and "f/r". I presume I have to supply an isolated power supply to the g540, and tie the "f/r" line high or low, but, what should the supply voltage be?
    2) I'm not sure what the mh ratings of the steppers are. If I limit to 2amps, is that ok? motors are 191 in-oz, 191 in-oz, 311 in-oz, x/y/z respectively.
    Thanks for any help/pointers you can give.
    JohnS.
    Aug 2011
    KX1 spindle control - cross fingers, the answer.
    Ok; the KX1 has a little board titled "XMT-SK".
    Have not powered on my mill yet, so this is a guess from taking the circuit apart.
    From looking at it, with the transformer on the top left, the left side connector, numbered 1 from the top to 8 on the bottom:
    1 - 110v input, load (black) wire;
    2 - 110v input, neutral (white) wire;
    3 - +5v from 7805 voltage regulator;
    4 - ground from 7805 voltage regulator;
    5 - optocoupler LED, cathode in 6N137 (not connected on my unit)
    6 - Forward/Reverse; tied to cathode of phototransistor (EL817)
    7 - grounded on my unit to pin 4 - tied to cathode of phototransistor (EL817)
    8 - to the ATMega8. Did not follow the pin; goes first through trim pot.
    Anyway, my G540 is still in the mail; but in case anyone else wants to know about a "XMT-SK" board; the above is my current take on it.
    Oh - and I found a label on one of the steppers; the X/Y direction are 3.0 amps, in case anyone is wondering. No label found on the Z axis yet.
    JohnS.
    Apr 2007
    Smile Sieg KX1
    I have a Sieg KX1 and cannot get used to the Sieg software which is installed in my Dell laptop. I would like to use mach3 but am not sure how to set up the modbus. I have been in touch with Sieg but am having difficulty communicating clearly. Instead of just changing the software to Mach3, they suggest returning the mill to China for a refit. Unfortunately my KX1 uses a cat5 cable where my other machines use the parallel port and Mach3. Anyone familiar with the Modbus etc?
    regards
    Bill
    Aug 2011
    Bill - I believe that Homann designs in Australia does the mod bus stuff.
    I also believe that he (and the devices) are quite active on the linuxcnc mailing list.
    I know that linux-cnc (the old emc2 software) is not Mach, but many on the list believe that it is a lot better than Mach!
    Anyway, whatever you do, from my limited experience, I'd keep the mod bus stuff. Homann Designs is the web page for them.
    (the Linux-CNC stuff does take a bit of head scratching, but I have found the email list very responsive. Now, plugging and playing Pendants, Joypads, touch probes, etc is very easy. Like anything that is capable of doing lots, it does take a bit of a learning curve, but once on that curve... Anyway, my thoughts for what they are worth)
  1. CNC-kit for Sieg X3/SX3
    By Novec in forum Norwegian Club House
    Last Post: 03-30-2012, 10:53 AM
  2. Sieg KX3 VS DIY X3 CNC
    By DonF in forum Benchtop Machines
    Last Post: 12-01-2010, 12:19 AM
  3. Got a Sieg x3
    By Outofreach in forum Want To Buy...Need help!
    Last Post: 08-03-2009, 05:40 PM
  4. Newbie- Sieg X1 retrofit with Linux EMC2, CNC Fusion retrofit kit and Gecko G540
    By GreenLead in forum Benchtop Machines
    Last Post: 11-27-2008, 12:55 AM
  5. Sieg X2 or X3?
    By david_geng in forum Benchtop Machines
    Last Post: 01-12-2007, 01:58 PM
