Old 08-09-2011, 11:10 AM
NE Brownstone's Avatar
NE Brownstone is on a distinguished road
Gecko 540 to drive nema 17s ???
Hi everyone,
Noob here. I have a Zenbot 6x8 mini bench-top router that had one of it's axis on the driver board go out. I've been thinking about upgrading to a drive with a 4th axis and everyone seems to love the gecko 540. I don't mind spending extra to get quality, but I don't want to over pay for overkill. The motors are 75 oz/in Bipolar Nema-17 1.8 degrees/step 2.0 Amps 4-wire. I know I can get the individual drives and build up a system that way, but I really am looking for as PnP as possible. Will this drive work, or is it overkill and will I need to look for another solution?
I wish the Zenbot guys would have used the 23's on this machine. End of story.
Just not a bunch of info for the 17s, well, not spoon-fed for this noob.
Thanks, any help would be much appreciated.
Russ
Old 08-10-2011, 09:19 AM
Nevermind
Found the info on the Gecko site, duh. I must say, it wasn't the easiest info to find, but I did. BTW yes, the 540 can drive the 17's. I's be ready to blast, now.
Russ Greene
New England Brownstone
Old 08-12-2011, 01:30 PM
rich909's Avatar
rich909 is on a distinguished road
Hi Russ --
Great! I'm glad you got the information needed. I don't know if you have made up your mind to go ahead with this or not yet, but I will be interested in your experiences and any discoveries ...if you do.
--Rich
Old 08-13-2011, 09:47 AM
Hi Jim,
Shean is sending out a chip for me to see if that fixes the problem, however I did order the g540, the 24v power supply and enclosure from Keling as Plan-B. I plan on keeping the original board as a back-up as long as the chip is the problem. I need to find some double sided thermal tape or get some thermal grease, or epoxy to keep the heat sink on the chip. I've read that heat transfer grease can be used if the corners are retained with a tiny drop of superglue. That way if the chip ever needs replacement I won't have to blast. From what I gather, the grease is much better of a transfer medium than the tape, which may be the reason the chip failed. I don't know.
I've never glued a heat-sink to a chip before and I guess I'll find out real quick. I'll document what I do and upload it to the yahoo group and here for anyone who may need to do the same thing.
Just playing the waiting game right now.
Russ
Russ Greene
Old 08-14-2011, 12:14 PM
dmauch is on a distinguished road
I have found that in many cases teh G540 and nema 17 motors don't get along together because the Nema 17's get really hot even if you reduce the current and voltage.
Dan Mauch
Old 08-14-2011, 04:03 PM
Dan Mauch
Oh well, now that's great! Where were you 4 days ago, hmmm? Just kidding, but seriously what's the worst that can happen? Will the motors or the board fry, or will the system just keep shutting down? If the chip replacement doesn't work I need another option. I need something to drive this thing.
Thanks for the input, before I fry $250.
Russ
Russ Greene
Old 08-14-2011, 06:42 PM
mharris220 is on a distinguished road
I think you have got a very good question, I have a G540 And wold like to use it on the smaller router I will building up later this year that will have some spare 17s
Thanks for the question Mark
Old 08-15-2011, 10:10 AM
I built an 8 axis system for a robotic arm that used two nema 17 motors.
The motors were good quality. The motors got hot even after reducing the current below what it should have been. Eventually the two motors fried but no problem for the g540.
If youmake sure that your current setting resistor is located on the connector at the g540 it will help. Also use the lowest voltage power supply you can get away with.
Dan mauch
Russ
Old 08-15-2011, 10:34 AM
Thanks Dan, any bit of info helps.
Luckily, most of my routing is very light work (Hydrocal plaster), which is soft compared to most materials people cut on cnc routers. More of a mess than anything. Here's an example of what I've done on the machine so. This was for a model railroad manufacturer I do some work for: NOTE: I only do the stonework. The rest is laser cut by the manufacturer.
I also used it to develop a set of patterns for scale bricks, which came out extremely well. The curve is due to the cheapie camera, not the machine.
I don't make production parts on the router, it is used only for pattern-making. I make a production mold and cast the final product.
Sorry about the pics not being Gecko related. Just wanted to show the nature of the work the machine is up against.
Thanks again and I'll keep everyone updated. The G540 comes in tomorrow.
Russ
Russ Greene
Old 08-15-2011, 10:59 AM
generally, I only vist this web site about once a fweek so sorry for not getting you more info sooner.
Looks great.
The biggest problem most people have is the G540 requires the PC bios to be set to the EPP Mode. EPP+ECP mode will not work. I would go ahead and check your bios seting first before hooking anything up.
If you run into problems you can contact me at dmauch at camtronics-cnc .com
Dan Mauch
[QUOTE=NE Brownstone;978847]Thanks Dan, any bit of info helps.
I also used it to develop a set of patterns for scale bricks, which came out extremely well.[IMG]https://nebrownstone.com/images/S-amer-bond-rul.JPG
  #11   Ban this user!
Old 08-17-2011, 02:47 AM
k_yarina is on a distinguished road
I have a Zenbot Mini with a G540; no problems at all with installation or configuration. It takes a bit of hand-eye coordination to solder the resistors into the DB9 connector, or see Soigeneris's connector board at EZ-G540 - Set of 4
The Mini's were made with a couple different belt pulleys, which affects the step size.
I'm using 1.8K resistors (didn't have any 2.0k on hand, and a 24V power supply. No problems with the motors overheating.
Kirk
New Machine Build- CHOSSING GECKO 540 WITH NEMA 34 STEPPER MOTORS EKFER Mach Software (ArtSoft software) 3 06-27-2011 11:50 PM
Need Help!- Nema 23 277oz and gecko G251 giant44256 DIY-CNC Router Table Machines 3 07-03-2010 07:34 PM
Problem controlling a Nema 42 with a gecko 212 Ragnarok Stepper Motors and Drives 1 02-22-2009 05:15 PM
Ayuda !! nema 23 y Gecko G-201 mad88 Spanish CNCzone 1 04-03-2008 08:47 PM
Nema 34 Motors 434oz/in / which gecko ckrantz Gecko Drives 1 10-01-2005 03:21 PM
