Old 07-14-2011, 11:05 AM
netomx is on a distinguished road
Want to build a servo feeder
Hello! I want to build a servo feeder. I want to put a dimension in a PLC and then drive a servo (with the gecko drive) to move X length if I activate a switch. My main problem is that I have nevewr worked with servos before. Is there someone willing to help me? I have a very old servo from a Strippit machine and I ElectroCraft servo, with its encoder.
Any advice would be appreciated. Thanks!
EDIT: I dont understand this part:
STEP 4: CONNECTING CONTROL INPUTS
The STEP and DIRECTION signal drivers must be 3.3V or 5V TTL signals and have edge transition times of 100 ns or faster. The COMMON input can be connected to signal ground or a +5VDC supply.
How can I generate this signal??? Is ther an explanation for this? Tried to look in Google but I don't know, maybe the work is driving me crazy
Thanks!
Old 07-14-2011, 11:25 AM
keebler303 is on a distinguished road
The step signal controls the speed and position. Number of pulses is distance, frequancy of pulses is speed of motor. One step pulse turns the motor one encoder count.
The direction input tells the drive to turn the motor forward or backward when it receives steps.
Matt
Old 07-14-2011, 12:22 PM
Thanks for your information, it is appreciated! My problem is solved
Thanks!
Tags
gecko, servo feeder
Problem- Servo bar 300 bar feeder dthiede Haas Lathes 4 08-27-2010 07:35 AM
Servo 300 Bar Feeder wudbutcher Haas Lathes 18 08-24-2010 10:17 AM
Servo motor build project... WilliamD General Electronics Discussion 13 11-27-2006 01:35 PM
Build a servo!? JBV Mechanical Calculations/Engineering Design 87 11-13-2006 04:49 PM
Please Help, build homemade servo driver. arwinasis juno Servo Motors and Drives 1 12-30-2005 08:50 AM
