Old 07-10-2011, 08:17 PM
FantomMfg's Avatar
FantomMfg is on a distinguished road
G540/ Laptop controlled / SSR Relay
I am trying to solve a Solid State Relay trigger issue. The SSR relay is triggered by 3-32VDC volts and the laptop puts out 1.34 volts. Is there a way to add a resistor to the SSR to increase/boost voltage output of the laptop? Sorry, electronics experience is minimal. Is it best just to use a desktop?The relays i use are -Fotek SSR-25 DA, Mach 3 cnc control software, Dell D600 latitude laptop.
Old 07-10-2011, 08:32 PM
Al_The_Man's Avatar
I'm typing this on a Dell D600!
Usually lap tops are 3.5v active high? I will have to measure mine.
But it should be possible to connect a 2N7000 gate to the P.P. output and switch the SSR with the output of the 2n7000.
Ideally the power for the switching could come from the D600 power adaptor, 19vdc, or another DC source.
If more than a few have to be switched then a ULN2805 could be used.
Search 2n7000 here for a circuit example.
Desk top would be better, but even then, a buffer as above is ideal.
Old 07-11-2011, 05:44 PM
FantomMfg's Avatar
Thanks for the input Al. I think i solved the problem. Hommann Designs has a wiring diagram, that shows output 1 goes to one connection (acts as ground) and on the same side of the relay a 3-32vdc power supply(Wall wort) is needed. This make sense now. I thought the output 1 / 2 was suppling the 3-32 vdc. Not so.
Tags
g540, x2 mill
G540 Relay Wiring - Quick Question strohkirchw Gecko Drives 0 12-06-2010 03:37 PM
Relay with G540 and a manual switch? 2nd try Fastest1 Gecko Drives 4 02-27-2010 04:22 PM
Need Help!- Gecko G540 Relay Help The CNC Man Stepper Motors and Drives 2 12-03-2009 04:11 PM
Need Help!- G540 and cnc4pc C8 relay blackrat Gecko Drives 0 04-22-2009 09:03 AM
Solid state relay controlled router codevark DIY-CNC Router Table Machines 0 03-25-2009 06:19 PM
