| Just got my G540 2 days ago. I try the following Setup : - No DB25 connection . - Pin 11&12 > 24V DC - Pin 10&12 EStop - Charge Pump OFF. -DB9 To My Motor 3A 4 wire - > 9Neg 8POS Phase A - 7Neg 6 Pos Phase B. -DB9 a 2.7K resistor to Pin 1&5 The Green light is On ( ) My Motor make a low noise sound . When I measure DB9 pin 98 I got 0V - but when I measured 7&6 I got 2.2V I think 2.2 V on 7&6 make that noise . Any sugestion ???????? Last edited by PleaseHelp; 07-02-2011 at 01:07 PM. |
Orin called and He sugested I Ground my computer, my power supply and my G540 . I went ouside put a piece of metal to ground and run the wire to my computer chasis , connect with db9 shield and power supply chasis . the Hum noise from the motor is still there . Measure pin 67 = 2.2v pin 98=0v |
I put my new 10000uf across pin 12 and pin 11 . The hum sound from my step motor is still lound and clear . Pin 6& Pin 7 of my DB9 is still 2.2 V . Anybody has any ideas ??????? |
I use a volt metter , put Neg on -B (pin7) , put Pos on +B pin 6 . The volt metter show 2.2 V Yes the motor run , Yes it is working but it is fair to have a silence motor when it is idle specially I payed $295 hard earn money for the G540. censor **************************************************** **************** G540's motor make that hum noise when it is idle, he just expect we live with it Last edited by PleaseHelp; 07-03-2011 at 01:28 PM. |
#12
| Thank You Doorknob . I will call Gecko on Tuesday . I am just very frustrating , I wish and willing to pay a little bit more money so I don't have to go through this debug hell . I am making another trip to get a set of capacitor : 2000uf , 4000uf , 6000uf ,(I already have 10000uf) , 12000uf , 14000uf . Frys Electronic charge $6 for each piece ( $30 ouch !!! ) Will test , and report back this afternoon. censor *************************************************************************** Last edited by PleaseHelp; 07-03-2011 at 01:28 PM. |
| Problem- G540 - output voltage? | llamatrails | Gecko Drives | 2 | 09-14-2010 04:10 PM |
| G540 Spindle speed output voltage problem | georgef8 | Gecko Drives | 5 | 09-22-2009 10:18 AM |
| g540 and over-voltage | draughted | Gecko Drives | 32 | 02-05-2009 01:55 AM |
| G540 Low voltage for E-stop and limits? | MrWild | Gecko Drives | 4 | 10-14-2008 04:28 AM |
| Help..Stuck at relay ext dc voltage missing but dc voltage OK ? | Dirky | Bridgeport and Hardinge Mills | 24 | 11-27-2007 07:33 AM |
