Old 05-12-2011, 08:35 AM
2ndserve is on a distinguished road
NEWBIE - G540 Fault problem (not charge pump)
I'm working on getting my system up and running. I (finally) got the thing up and running with the chargepump on from what appeared to be a working MACH3 install on my computer. Nice green power light instead of the fault light indicator.
I walked away for a moment and returned to see the fault light on.
It now won't come out of fault with the chargepump on or off - parallel cable installed or not.
I should also mention that I had this problem once or twice prior to getting the charge pump signal situation resolved.
I tried some searching to see if others had the same problem but nothing popped out at me.
Any thoughts as to why this is happening would be greatly appreciated.
Brad
Old 05-12-2011, 12:13 PM
SOLVED: In this particular case it was a bad DB9 cable - once I removed it everything seems to be in order as I'm getting movement on the other axis
G540 charge pump & Mesa 5i20 cartula Gecko Drives 11 04-28-2011 11:05 PM
Need Help!- G540 charge pump fault, no motion. Settings? JosephD Gecko Drives 8 06-16-2010 02:47 PM
G540/Mach3 charge pump fault LED is lit will gilmore Gecko Drives 42 04-12-2010 08:26 PM
G540 charge-pump not pumping aystarik Gecko Drives 2 05-14-2009 02:38 PM
G540 Tempremental charge pump detector David Campbell Gecko Drives 1 03-20-2009 07:18 AM
