Old 05-01-2011, 05:12 PM
jhowelb is an unknown quantity at this point
G203V with "issues"
Using three G203V's with a Model PMDX-132 and identical motors.
2 axes work beautifully but the third just kinda buzzes the motor and makes it try to turn but can't quite cut the mustard. With no other changes but changing the position of that little Gecko with any other and the "issue" follows the suspect drive.
"Error of Opinion may be tolerated where Reason is left free to combat it." - Thomas Jefferson
Old 05-23-2011, 04:06 PM
One more example of why I'm such a big fan of Gecko drives:
I shipped it back to them with the request that they repair and return. A blank check, I just wanted my drive fixed. I've already replaced it with a brand new 203V but because stuff happens, i wanted a spare.
A few days passed and the drive returned. They had found a cracked component and replaced and tested it.
My only expense was the shipping back to Gecko.
This was a hard learned lesson. With another drive maker, a few years back, there was all kinds of grief and repeated burned components and lots of accusations that I just did not know what I was doing.
.....they were right, but I did learn.....BUY GECKO!!
Old 05-23-2011, 04:42 PM
Crevice Reamer's Avatar
Crevice Reamer is on a distinguished road
You can't go wrong with Gecko.
CR.
http://crevicereamer.com
Too many PMs. Email me to my name plus At A O L dot com.
How to "offset" Double sided PCB if I don't have abolute "home" on my CNC ? Calico PCB milling 11 07-12-2011 06:02 AM
"No region found" issues margni74 Rhinocam 1 10-24-2009 01:34 PM
Need Help!- "motor steps per resolution" and "driver microstepping" settings margni74 LinuxCNC (formerly EMC2) 9 10-24-2009 02:33 AM
"J" head type "millport"(tiwan,1980) clutch marksbug Bridgeport and Hardinge Mills 1 08-17-2009 10:48 AM
Has anyone looked at the "JET" or "Shop Fox" manual machines? boosted General Metal Working Machines 12 03-04-2007 09:33 PM
