Hello, My mill is: Hurco KM3P knee mill. Servo motors are 90VDC, 12 Amp continuous, 20 A peak. Will the Gecko 320x drive these? Also I need a new power supply. Mine is putting out 92 VDC, through the rectifier. Can I run 80 Volts DC through the Geckos, or should it be a little lower? Need a recommendation for the power supply, or preferably just a transformer supplier. Thanks, JAckal
__________________ Everything is bio-degradable, if you run over it enough times with the lawnmower. |
| Yes, the G320X will drive these motors. The G320X is limited to 80 volts, so you will need to get your power supply down to 80 volts or less. I usually recommend 72 volts or less to allow for 10% power line fluctuations. Lower voltage maps directly 1:1 to lower top end speed, but your original machine likely did not use 90 volts to drive the servos. Running them a 72 volts will result in a close enough to the original performance for most purposes. Lower voltage has minimal effect on maximum torque and acceleration. Regards, Steve Stallings www.PMDX.com |
| Thanks Steve, I appreciate the reply with good information. There were a lot of views but no one answered yet. I'm still knocking around my decision. The availability of the Geckos means a lot. Sometimes other brands are sold out, and you have to wait........................................................................... Warranty or not, it is nice being able to get another drive within 24 hours. Do you have a recommendation for a transformer? Thanks, JAckal
| For good prices on reasonably good transformers, it is hard to beat Antek. http://www.antekinc.com/ Remember that the DC voltage from a bridge rectifier will be approximately 1.4 times the nominal AC input voltage. The AN-10450 or AN-15450 transformers would be suitable, with the former be OK for most users and the latter if the machine was expected to run under full load most of the time. Regards, Steve Stallings www.PMDX.com |
| Steve, I see that they show voltage rating under load . I don't know how they load them down, but my transformer says 60 volts AC & calculated it to be 84.84DC with a bridge rectifier. When I checked it last week ( No Load ) the transformer was putting out around 64.9 volts AC. That comes to around 92VDC through the caps. This is what made me re-think my servo drive selection. They would probably load test it similar to the method used in checking an automotive battery under load. How much difference is there in Load VS. Non-load ratings? Some sort-of "Rule of thumb"? Thanks, JAckal
| Have you looked at taking turns off? Toroidals are easiest but EI laminated can be done, I have done a few in my time. For toriods it works out to around 2turns/v, square laminated it could run to 3 or 4. No need to recalculate the VA requirements either! Al.
| Al, This one is laminated. I wondered the other day if you could remove windings on it. If my original plan falls through and I end up with a lower voltage drive, I will try to unwrap a few coils on this one. It will be no use to me if my drives are 80V. I'll let you guys know what happens in a day or 2. Thanks for the info, JAckal
| The amount that the loaded voltage drops below the unloaded voltage will depend on the amount of load, the source impedance of the transformer, and the amount of filter capacitance. Relying on the loaded voltage being lower is not a good idea because it could become higher when motors are at rest, or even worse, slowing down with the mass of the machine trying to keep them moving. This results in the motor generating a voltage (back EMF) that sends current back in to the power supply unless your drivers have provision for braking resistors. This is primarily an issue with servo motors, and can cause the supply voltage to rise above even the unloaded voltage in some cases. Most of the time when one motor is returning current, there are other motors that are not slowing down and they will consume it, so the voltage will not rise above the normal peak supply voltage of the power supply, but it can happen. Regards, Steve Stallings www.PMDX.com |
| My mill has the EMF capacitors on it from the factory. Could they be dried out and need replacing? Here is a link where I asked about them: http://www.cnczone.com/forums/hurco/...citors_my.html And another link where Al_the_man gives me more info about them. http://www.cnczone.com/forums/genera...my_servos.html When the transformer comes out, I'll post some pics before working on it. Thanks, JAckal
#10
| An extreme failure could be caused by a very large spike puncturing the insulation, in this case they usually go short circuit. The resistor in series is supposed to prevent this however. Al.
#11
| Al, That is good to know. Later today, I'll get the transformer out and take look at it, plus post some pics. Thanks for all of the help, JAckal
| Need Help!- Why use breakout board with Gecko 320X? | pp7 | Benchtop Machines | 6 | 04-18-2011 02:10 AM |
| 320X Problem after changing encoders | toadjammer | Gecko Drives | 8 | 02-04-2011 12:08 AM |
| Can LED on 320X be used to trigger devices? | simpson36 | Gecko Drives | 0 | 06-27-2010 08:33 AM |
| Gecko Drive | Don Kellogg | DIY-CNC Router Table Machines | 8 | 08-10-2008 12:12 PM |
| Which Gecko Drive | Lloyd | Gecko Drives | 5 | 05-31-2006 01:35 AM |
