Old 04-23-2011, 08:36 PM
Smike740 is on a distinguished road
G320 Ok with no motor connected
Hello,
I am finishing up a 4 axis controller for a Bridgeport mill conversion using 4 G320 drivers (not 320x). The 4th axis will drive a rotary table when needed. Is it OK to keep power connected to the unused G320 (A-axis) without the motor and encoder plugged into that drive? I know its not OK to plug or unplug the motor with the Gecko powered.
Thanks,
Mike
Old 04-24-2011, 08:42 AM
morestuff is on a distinguished road
No physical harm should come to the drive as long as you do not make or break the motor connection while power is applied.
On the other hand, the feedback loop will not be closed so the drive will instantly go into a fault condition. If you have the ERR/RST pins of all your drives connected together, then all of your drives will shut down. It is often desirable to tie the ERR/RST pins together so that all motors stop if any drive faults.
Regards,
Steve Stallings
www.PMDX.com
G320 and a 850oz-in motor edwardvm Gecko Drives 4 09-20-2009 04:45 PM
G320 - reversing default motor direction radioactive Gecko Drives 0 04-07-2009 03:20 PM
G320 servo motor tuning robhrzic Gecko Drives 12 11-01-2007 01:35 AM
G320 Suitability for a motor rated at 140 max volts? sbalder Gecko Drives 0 04-12-2007 03:56 PM
Is this motor suitable for g320 gcamlibel Gecko Drives 0 04-16-2005 12:00 PM
