Old 04-16-2011, 10:12 PM
Bossman1 is on a distinguished road
My G540 all of a sudden doesn't work
I disconnected my g540 to take the computer cabinet in my house last year. The powersupply was in the cabinet as well. Simple 2 wire disconnection.
I decided to go out and play around with my plasma table. Hooked everything back up, and now there are no "power" or other lights on my gecko. I have confirmed 24v are present at the terminal.
Since I haven't used this setup for quite awhile, my memory on what it takes to make it all work is a bit fuzzy. But it should at least indicate "power" with no other inputs, right?
Edit: After some research, I must have reversed the polarity. There is a resistor inside that from what I found, is the "polarity" police. It is a 2W, .04 ohm resistor. Where can I find one?
Old 04-27-2011, 11:35 AM
dmauch is on a distinguished road
The G540 are very robust. They will take all kind of abuse including short circuits. First thing to check since you moved the G540 are you sure you have connected the correct power supply V - to terminal 12 of the G540 and V+ from the power supply to terminal 11. See the G540 data sheet to be sure.
You also mentioned two wires. You will also need to wire the disable terminal 10 to a switch with the other end of the switch connected to power supply ground.
Dan Mauch
Camtronics, inc. -- CNC with Dan Mauch
kits, custom and azssembled system using wonderful Gecko Products
Old 04-27-2011, 11:57 AM
Thanks for help. I got it running again. Found a post on the Yahoo group describing the little "fuse" resistor that is inside and where to buy them. Picked up a few, and it fired right up once I had the polarity correct.
will these limit switches work with my G540? SatanKlawz DIY-CNC Router Table Machines 2 03-19-2010 02:06 PM
G540 HELP, cant get it to work dougie329 Gecko Drives 8 07-03-2009 05:50 AM
Need Help!- Sudden stepper inversion precourt Machines running Mach Software 1 04-27-2008 05:39 PM
Need Help!- All the sudden, big problems with Rapids SpeedsCustom LinuxCNC (formerly EMC2) 2 04-24-2008 09:44 AM
Centurion 6 Sudden Stop TZ250 Milltronics 3 10-22-2007 11:55 PM
