Old 03-29-2011, 10:52 AM
Action-KAT's Avatar
Action-KAT is on a distinguished road
Oops where did my limit switches go
Has any one had a problem like this before
Last night I started putting some T track on my bed,
booted my baby up and tested my switches as I always do as a startup check,
found my limit switches were not working.!
using a Gecko G540 & limits in series all worked before never a problem.
my home switches still work & these are the same just wired the other way.
after testing bits n bobs I tried moving the input wire from pin 1 to pin 4 on my G540 & found the switches worked fine !
hope nothings blown haven't even finished building yet only run a couple of tests.
Anyone have any ideas what's up,
I will check what settings etc on my setup later
KAT
Old 03-29-2011, 05:32 PM
Action-KAT's Avatar
Even more confused now,
came home tonight to finish setting in my t track & now the limits have stop working again in the different G540 pin.
carried on cutting the bed & had to turn the controller off a couple of times.
Turn it on again & now the work again !
at a loss what I should be looking for,
I don't get any false tripping & not triggered on startup so this should mean no break in the cabling.
any ideas where to start looking.?
I'll finish the T track & then earth all the connections etc. & see if that helps
cheers KAT
Old 03-29-2011, 07:20 PM
MattTheNoob is on a distinguished road
What kind of switches are they? Are these 2-wire mechanical switches or a prox switch of some sort?
Once you cycle power a few times and they start working, do they stay working? i.e. is it the power cycle that is breaking / fixing them?
I certainly don't have the answer. I'm just throwing out fodder for the debug effort.
Need Help!- Home switches and Limit Switches TheBulk DIY-CNC Router Table Machines 5 03-12-2011 05:08 AM
Limit switches and homing switches AeroKam Open Source CNC Machine Designs 16 01-05-2008 07:56 AM
The relationship of limit switches to home switches. MikeAber General Electronics Discussion 4 11-04-2004 01:28 PM
Limit switches and home switches viktorcnc TurboCNC 2 08-03-2004 06:11 AM
Home switches and limit switches. ynneb General Electronics Discussion 5 04-08-2004 05:32 PM
