Old 08-10-2005, 10:55 AM
HansM is on a distinguished road
G201 to 6-wire stepper wiring?
I just purchased a RHT23-270 stepper motor and a GeckoDrive G201 to drive it from www.homeshopcnc.com. I'm not sure how to wire it up. I want to wire the motor Bipolar, for which it is rated 270 oz/in and 2.8 Amps, 3.75 Volts. The wiring diagram below came with the motor. So, should the wiring be:
Black Phase A
Green Phase B
Red Phase C
Blue Phase D
Yellow Not used
White Not used
Does that look correct?
What value resistor should I use on the G201 for this motor? They say to use 18K for 2A and 36K for 3A, so should I use 25K for 2.8A?
Also, what Voltage should I feed to the G201 for this motor?
Lance
Old 08-10-2005, 11:09 AM
MrBean's Avatar
Gold Member
MrBean is on a distinguished road
I would say you'd get better results by wiring the motors bipolar half winding. That way you can use the steppers full current. Use a centre tap and one outer wire to make each phase.
eg.
white/blue ---phase A/B
yellow/green--phase C/D
Regards Terry.....
Old 08-10-2005, 11:12 AM
Gold Member
CJL5585 is on a distinguished road
Originally Posted by HansM
Black Phase A
Green Phase B
Red Phase C
Blue Phase D
Yellow Not used
White Not used
Lance
Your wiring above is correct. The resistor value should be 36K (for 3 Amps). The voltage has to be 24 VDC or greater. I would recommend a voltage in the range of 30 to 40 volts DC. Just make sure you fuse each Gecko + voltage line with a 5 Amp fast-blow electronic fuse.
Hope this helps.
Jerry
Old 10-30-2005, 02:06 AM
Calico is on a distinguished road
Hope this helps.
Jerry
hi jerry,
just wondering why you said 30-4- volt DC, I thought 20-25 times the voltage is recommended ?
so in this case 70 volt ?
regards
ruddy
Old 10-30-2005, 05:31 AM
Gold Member
hi jerry,
just wondering why you said 30-40 volt DC, I thought 20-25 times the voltage is recommended ?
In the previous post, the voltage was recommended due to the heating of the stepper motors during operation. The higher the voltage, the hotter the stepper motors will get during extended operation. If the steppers exceed the temperature rating on the nameplate, they can de-magnetize and ruin the motor. My system runs on 48 VDC, and I can only run the CNC 2 1/2 hours without allowing the motors to cool off.
Jerry
Old 10-30-2005, 05:52 AM
ger21's Avatar
20 to 25 is the MAX recommended. The best voltage to use is the lowest that will give the performance you need. Any higher just causes extra heat. If the motor runs as you need at 30V, running at 60V will just give you a much hotter motor.
Old 03-01-2006, 10:37 AM
stevenmotor is on a distinguished road
I think you will make a trouble if you use a unipolar stepper be a bipolar stepper.The motor heat will rise soon and the torque will be drop down.
TO choose the right stepper,Please e-mail: mct.motor@msa.hinet.net
Steven
