I am building my second CNC router and am re-using my Gecko G540, steppers, and cables from my first machine, where they worked with no problems. I am using Mach3 with an Xbox360 controller to manually position the router. It uses a USB port and interfaces with a plugin that someone wrote for it in Mach. One of my axis just starts taking off without any input from me. It is not a constant velocity and may or may not stop on its own. I swap cables on the G540 and the problem follows the G540 channel, not the stepper/cable assy. Does anyone have any ideas on what the root cause might be? I have searched various forums, google, etc. and either I'm not using the right search terms or no one else has seen this. |
| If the DRO's in Mach3 are not changing while the axis is moving, then it's not coming from Mach3.
| Sounds like the XBox controller is causing it then.
| Intermittent stepper problem | HomerSimpson | Mach Software (ArtSoft software) | 2 | 03-10-2011 09:49 AM |
| Intermittent pauses at every 1.8 degree for stepper motor | fujima4 | Stepper Motors and Drives | 3 | 03-05-2011 08:41 AM |
| Need Help!- G540 spindle control problem | rewster | Benchtop Machines | 8 | 12-18-2010 05:14 PM |
| Need Help!- Powermax 1000 intermittent "no start" problem | MoparJon | CNC Plasma and Waterjet Machines | 14 | 12-17-2008 02:59 PM |
| Stepper control problem | climberfreak66 | Stepper Motors and Drives | 7 | 10-29-2006 05:24 PM |
