Old 02-27-2011, 12:10 PM
HereinCS is on a distinguished road
Wiring gecko g203v to makerbot motherboard.
I have some gecko g203v sitting around and decide to try to use them with my 3d printing machine project. I just want to see if the terminologies are clear before I fry my boards. The makerbot pin out put description is:
1 N/C This pin is unused and not connected to anything on the motherboard.
2 GND This pin is connected to ground on the motherboard.
3 STEP This pin is the step pin, and will send a pulse to the stepper driver when it needs to take a step.
4 DIR This pin is the direction pin. HIGH = forward, LOW = reverse. This can be configured in software.
5 ENABLE This pin is the enable pin. LOW = enabled, HIGH = disabled. This pin turns the stepper driver on or off. This can be configured in software.
6 N/C This pin is unused and not connected to anything on the motherboard.
My g203v has:
1. Common
2. Step
3. Dir
4. Disable
Where Makerbot label is enable, gecko is disable: is this equivalent?
GND on the Makerbot equal to Common on gecko?
Thanks.
PMDX-133, new motherboard for 3 / 6 Gecko drivers morestuff Product Announcements & Manufacturer News 7 07-30-2011 04:45 AM
Gecko motherboard drafterman Gecko Drives 4 12-17-2007 04:57 PM
X3, Gecko G203V and what else.... KOS Benchtop Machines 10 05-27-2007 10:08 PM
