Old 03-12-2003, 02:52 PM
cncman2's Avatar
cncman2 is on a distinguished road
Does Gecko
sell drivers for stepper motor's? Can I add a encoder to it?
Old 03-13-2003, 02:11 PM
*Registered*
Andrew is on a distinguished road
Yes, the Gecko 201 and 210 drives control stepper motors.
Old 03-17-2003, 08:16 PM
CNCadmin's Avatar
Site Owner
CNCadmin has disabled reputation
I order the 201, any pointers on using them?
Thank You,
Paul G
Site Owner-Webmaster-
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
Old 03-18-2003, 04:13 AM
CNCnUtZ is on a distinguished road
Yeah. Get one of these theyre a must if you want to protect your investment http://members.shaw.ca/axxus/db1v20.htm
He sells them on Ebay too..Search for "CNC parallel" 50-60 bucks. Well worth it IMHO
Also, make sure you mount the gecko drives to a nice sized heatsink because those puppies do GET HOT.
You make anything to mount them in yet?
Old 03-20-2003, 12:37 PM
cncman2's Avatar
Cool thanks, I will check that out. I have not made anything to mount then yet, any sugestions?
Old 03-22-2003, 07:32 PM
Well, I went to an indoor fleamarket that we have here in town, and he had a exorbitant amount of old pre-486 PC's.
I took an old desktop type case and gutted it and mounted all my drives and power supply, ect. inside.
I use the existing switches for the power to the drives in case of an emergency, it all can be switched off rather easily(its one of those huge toggle switches)
If I were you, I would look around for a place that has a bunch of these old PCs and get a case or 2 to mount everything in.
Or alternatively, you could build a case, but why do that ,when you can probably find someone around where you live ,that ahs one of those aformentioned cases and most likely get it for free.
Good luck.
What are you going to run the system with(controller wise)?
Old 03-24-2003, 03:59 PM
CNCadmin's Avatar
Site Owner
Mach1
Thank You,
Paul G
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
Old 03-24-2003, 04:01 PM
johnm is on a distinguished road
I tried out the demo looks very good. Runs the stepper motor perfectly.
John M
Old 03-24-2003, 06:12 PM
Originally posted by CNCadmin
Mach1
Same here. Definately a wise choice as Art has done a super job on Mach 1/2........runs smoother than DOS controller packages ive tried.
WELL WORTH IT IMHO
Gecko Drive, Banner Competition, Finalists Voting ynneb Polls 31 03-23-2005 11:04 AM
Gecko vs Rutex samualt Gecko Drives 20 10-21-2004 02:48 AM
Servos or Steppers..... and other gecko related questions UKRobotics Gecko Drives 11 04-19-2004 03:14 PM
To Gecko, or not to Gecko...that is the question! samualt Gecko Drives 11 09-22-2003 09:42 PM
