| Vguerrao, The G540 is a bipolar driver, leave the center tap (black & white wires) unconnected. Jeff...
__________________ Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish. |
FULL STOP alert!! The Sherline plug connects the center of the two windings in the motor to the same pin! This will probably kill the G540! If you are using motors with the Sherline plug still on the motor cable you must disconnect the two center wires from each other. Simply not connecting to that pin on the plug is not sufficient. Once you have the wires separated, then you will have a choice of running the motors as bipolar motors using the full windings or as half winding by using one end and the center tap of each winding, while the other end of the winding is not connected. This will usually be the preferred method because it results in lower inductance (and thus faster speeds) at no, or only a slight, penalty in torque. Regards, Steve Stallings PMDX.COM - Products for CNC and motion control applications |
| Hi vguerrao , you need to be able to disconnect the four half coils from the common terminal / wire and reconnect the four wires to form two seperate coils if the motor has a 5 way connector , the windings are likely to soldered to a pcb that makes it easy . with 5 wires , it will depend on the common joint not being buried and being easy to rewire I think I read some were , the rotor will be partly demagnetised if removed I expect some one can confirm if it is true John p.s. eg picture of stepper motor pcb and 6 way connector you may have to de-solder the pcb to gain access to the common wires Last edited by john_100; 01-29-2011 at 11:12 AM. Reason: add picture |
| The information you need is in the preceding posts, but having done what you are trying to do I thought I'd add a few comments. The stock Sherline motors are six wire motors, with the center taps of each winding soldered to the center pin inside the five pin connector. A wiring diagram can be found here by clicking on the link to technical specifications. Sherline Stepper Motors The Sherline motor inductance is a far better match for the G540 if used as half winding. To do this, referring to the diagram in the link, brown and black become one winding, red and white the other. Orange and yellow are left unconnected. I started off by replacing the Sherline connectors with these similar four pin connectors Digi-Key - CP-1040-ND (Manufacturer - SD-40), but have since replaced those with the ones from DY engineering.D.Y. Engineering - NEMA23 Cover Kit Regards HR |
| I have 6 wire motors can I use a 4 wire driver | Musick7 | Stepper Motors and Drives | 10 | 05-05-2009 10:39 PM |
| Need Help!- Connect my PS to the driver | pietervanstee | Stepper Motors and Drives | 0 | 03-08-2009 06:51 PM |
| need help to connect microcontroller to stepper driver | xinzc28 | General Electronics Discussion | 0 | 11-07-2008 02:59 AM |
| connect wire leads to IC | Karl_T | General Electronics Discussion | 2 | 06-11-2008 12:15 PM |
| Wanted DIY stepper driver circuit for 6 wire stepper motors | Colin300 | Australia, New Zealand Club house | 5 | 09-20-2007 09:20 PM |
