Old 01-17-2011, 02:17 PM
woodman08's Avatar
woodman08 is on a distinguished road
terminal block on the g203v
I started having trouble getting the z axis to move ,checked for loose connections etc,drives all showing green light and motor stiff when power is on ,so its a control problem,After much looking around all the wiring it turns out its the terminal block toch it and the z works momentarily so i pulled the terminal block (2of) and put it back on and the z is ok,should these contacts be cleaned
Gecko is sending me some new blocks
Old 01-18-2011, 09:10 AM
Gold Member
Mariss Freimanis is on a distinguished road
How old are the original terminal blocks?
Mariss
Old 01-18-2011, 10:09 AM
woodman08's Avatar
terminal blocks
my machine was built in 2007,and gecko is sending a new block
I am surprised but they are push on push off and i have never touched them till now (them i should say the z axis one)
DC Terminal block or bus bar DrStein99 General Electronics Discussion 2 09-21-2009 12:03 PM
Terminal Block Smackre General Electronics Discussion 3 11-18-2006 01:34 PM
Pluggable terminal block? lockeyone General Electronics Discussion 2 10-28-2006 08:41 AM
RS232 program block by block smoregrava General CNC (Mill and Lathe) Control Software (NC) 3 12-22-2005 12:52 AM
terminal #37 utengineer04 Bridgeport and Hardinge Mills 1 09-07-2005 01:40 PM
