Results 1 to 2 of 2
Thread: G201 -vs- G202 -vs- G210 -vs- G212
    Jun 2005
    Talking G201 -vs- G202 -vs- G210 -vs- G212
    I am looking at buying gecko drives to run my steppers but i am not sure which I should purchase.
    It looks like the difference between the 201 and the 210 is the steps. If i am correct the 210 produces 10 steps for every one that is sent to the drive.
    Is this a good thing and how do i know if this is the way to go.
    The 202 and the 212 have just shown up on the site but i would also like any info that can be given on them.
    I would like to get my drives ordered so i can play around with the motors before i start to design and build my cnc.
    Any help would be greatly appriciated.
    May 2003
    I recently built a 3 axis stepper system using the G202. They are bullet proof. I deliberately shorted out the outputs of A to B, then A to C and last C to d
    As advertized they paused then went right on working after the short was removed. Also disconnected the stepper motor under power which is also a no-no. It was no problem.
    I prefer the G201 over the G210 because the G210 tends to be fussy about the timing for the direction change. But if you have a large number of steps per inch say 50,000 then sure the G210 would be the better choice. I would say the G210 is the better deal up to 35000 steps per inch
    Dan
    www.camtronics-cnc.com
    low cost stepper motors and cases for G201/G210
    Quote Originally Posted by DJB282000
    Dan Mauch
    Camtronics Inc
    dmauch@seanet.com
    www.seanet.com/~dmauch
