Old 12-27-2010, 09:37 PM
studysession is on a distinguished road
Gecko 540 question (noob)
I have 3 4 wire motors. I am want to upgrade to a Gecko 540 driver
G540 4-Axis Motor Control
Do I have to order special cables to use this or can I connect my 4 wires to the pin ports on the side? If I should use the cables, could you please provide a link to an inexpensive resource?
If anyone has used the pin ports on the side could they please post a picture and explain their setup?
THANKS!!
Please check out my CNC blog
http://cncinside.com
Old 12-27-2010, 10:02 PM
Dean448 is on a distinguished road
The manual shown on that web page you have the link to shows how to hook up your motors. They go into the DB9 connetors on top of the unit. Use pins 6-9 and add current resistor to match the amp rating of the motor. You might be able to buy the connector but you can also wire one up. Its not difficult.
Dean
Old 12-27-2010, 10:04 PM
THANKS!!!
Noob question jcposada Mini Lathe 12 05-31-2010 10:03 AM
Need Help!- noob question brou1 Stepper Motors and Drives 2 11-24-2009 03:34 AM
noob question epoxie Benchtop Machines 4 10-06-2009 03:08 AM
nOOb Question Tazzer General Metalwork Discussion 2 07-22-2009 07:41 PM
Noob question PBfan General CAM Discussion 12 07-05-2006 11:19 PM
