Old 12-21-2010, 10:42 AM
MArruda is on a distinguished road
G540 signal input
Hello all,
I'm trying to make a "1 penny touch probe" ( The "One Penny" Touch Probe ) to work with my G540. I have a regular 6 ball & 3 shaft kinematic from wildhorse designs, and I'm very dissatisfied with it- it is constantly staying open and wrecking my scans. This is for a product I'm working on that I have to have a usable 3d model of by the end of the year for work, so it's ticking me off.
Anyway, my question is, I built the touch probe above and wired it into the g540, pulling a signal from one of the inputs- 12v- and outputing to another input. As soon as I connect the probe, the input I'm pulling power from closes, as expected, but so does the output of the probe, no matter if the contacts are closed or not. I know it's supposed to be a 5v input, but I tried it with the 12v from the gecko anyway; I figured, worse case scenario, I'd blow the transistor and have to replace it. the resistors are dropping the voltage to about 8.3 or so.
Any ideas would be greatly appreciated,
-Michael
Old 12-23-2010, 08:22 AM
Jeff-Birt's Avatar
Jeff-Birt is on a distinguished road
You can't try and pull power for your probe from an input, it simply won't work. You need an external power supply.
Jeff Birt
Manuals and check input signal sarniamachining Cincinnati CNC 2 02-17-2010 06:02 AM
stablizing vfd input signal keithmech General Electronics Discussion 1 04-23-2009 03:24 PM
Need Help!- Input/output signal on 0M-C padobranac Fanuc 3 10-28-2008 09:49 AM
Input signal fails when powering up drivers. Witsenburg General Electronics Discussion 2 07-02-2007 03:02 PM
Physical Button Signal Input Triggering Macro sunmix Mach Software (ArtSoft software) 0 08-24-2006 10:26 PM
