Page 3 of 3 FirstFirst 123
Results 25 to 33 of 33
Thread: G540 motor cable issues
  1. #25
    May 2005
    canada
    Quote Originally Posted by jsantos View Post
    My G540 did not come with db9 connectors. How do I get these connectors?
    These look like a possible candidate ?
    Digi-Key - 609-1524-ND (Manufacturer - DE09P064TXLF)
    Solder cups large enough for 20 awg is no guarantee of rated current handling above 3A.
    My mistake for not checking. For me this is only a bit of a solder job, or at least I hope the female DB9's on the G540 have no damage. Overall the Gecko resellers are good people trying to provide a service and make a buck, I hope this all gets ironed out to everyone's satisfaction
    Anyone who says "It only goes together one way" has no imagination.
  2. #26
    Registered Jeff-Birt's Avatar
    Feb 2007
    Is the cable at the G540 a solid molded piece? If so then the resistor can't be there. If it has as DB9 backshell that can be taken apart, take it apart and look for the resistor.
    If anyone is worried about your cables drop me a PM or email 'birt_j at soigeneris dot com'
    Jeff Birt
  3. #27
    Registered CoAMarcus's Avatar
    Jan 2007
    Quote Originally Posted by cyclestart View Post
    If you send your mailing address to sales@geckodrive.com or directly to me at geckomarcus@geckodrive.com we can send you a G540 connection kit for free.
    Marcus
  4. #28
    Gold Member
    Mar 2003
    jsantos,
    Make what's wrong right. Leave what's right alone.:-)
    Mariss
  • #29
    May 2005
    canada
    Quote Originally Posted by CoAMarcus View Post
    Marcus
    Thanks, that's a very generous offer.
    I bought directly from Gecko and got the 4 DB9's that I was entitled to in the deal and I don't feel you owe me any extras. Is the Digi-key item I linked to unsuitable in some way ?
    If the current set was placed somewhere less convenient, the temptation to hook-up extra machines would be reduced. Don't tell the Sales Department !!
  • #30
    Dec 2009
    Quote Originally Posted by Mariss Freimanis View Post
    jsantos,
    Mariss
    Gotcha! I will do that. Thanks!
  • #31
    Registered Arbo's Avatar
    Jan 2008
    Ok, my machine has been running without issue for quite some time now (issues related to cables)... Using the cncrouterparts cables. Guessing they are fine. Now I need to take the resistors out of the motor end and build a little plug to put it on the other end?
    Kinda sounds like a pain.
    I don't recall getting any db9's when I bought my G540... but that was a long time ago... I know the shells I have are radio shack grey shells.
  • #32
    Dec 2009
    Quote Originally Posted by Arbo View Post
    Call Gecko. They'll send you the db-9s. But since it looks like Gecko is doing something about the problem, I'd probably just wait.
  • #33
    Jan 2008
    eh, it's been a long time, mine might of come with them...
    But either way, where can you pick up good quality db9's, both male and female to put together an adapter to put between the cable end and G540?
  • Page 3 of 3 FirstFirst 123
    1. AC power cable in the same cable carrier with motor cables
      By bandtank in forum General Electronics Discussion
      Last Post: 06-01-2010, 07:06 PM
    2. Need Help!- G540 PC comunication issues...
      By CNC74 in forum Gecko Drives
      Last Post: 02-10-2010, 11:15 AM
    3. Which parallel cable for G540? Standard or IEEE?
      By bkboggy in forum DIY CNC Router Table Machines
      Last Post: 03-31-2009, 10:17 PM
    4. Standard or IEEE parallel cable for G540?
      By bkboggy in forum Gecko Drives
      Last Post: 03-30-2009, 06:28 AM
    5. Newbie- Motor Cable ????
      By themonster in forum General Electronics Discussion
      Last Post: 07-24-2008, 11:30 AM
