Before I fry a second driver I thought I would ask the group. How do you wire terminal 12 on the g251? The documentation states logic ground and I am slightly confused as to what it means. I have a c10, rev7 bob. Any help would be greatly appreciated. Adrian |
| Here is how I wired mine to the C10 ![]() There is a jumper on the C10 to set the COM terminal to 5V or GND. I set mind to GND. Also mine is the C10 revision 8.2 and the inputs have 4.7K ohm pull own resistors. I had to cut them out and use pull up resistors on my inputs. Also, this is the very first revision of the G250 so it required a 100 ohm resistor on the logic ground ... I don't think it's required any more. I am attacking a higher-res image if you need it. -Jay |
| Jay, Thanks for the helpful information. The rev 7 bob doesn't have a jumper fror the 5v/gnd function. I am assuming if I connect to this terminal and I do not send a 5v signal, then it defaults to gnd. Is my thinking correct? Thanks once again! Adrian |
| I wouldn't assume anything. I don't see the v7 manual on the cnc4pc website. My suggestion aside from sending an email to them for confirmation is to use a multimeter and look for continuity between GND and the COM. I suspect that you are supposed to connect either 5V or GND to one of the COM pins. That way all of COM's will share the same logic level. |
| g251 questions | Jack000 | Gecko Drives | 10 | 03-16-2009 03:05 PM |
| Ground loop G251 | Jay C | Gecko Drives | 5 | 12-22-2008 11:37 AM |
| Frame ground vs. Electrical ground. | polaraligned | Granite Devices | 2 | 11-24-2008 04:21 PM |
| Need Help!- To Ground or not to Ground That is the question! | Mr.Chips | DIY-CNC Router Table Machines | 1 | 03-16-2008 03:10 PM |
| Motor supply ground vs Logic ground? | Gashmore | General Electronics Discussion | 11 | 06-07-2005 05:21 PM |
