Hello. Im currently using an 250 CPR encoder with my Gecko G320. It works good, but due to my 1:1 drive ratio I need something with more resolution. Has anyone ran those drives with 1024 CPR encoders? |
| Normally you don't do that with a servomotor. Servomotors are high RPM, low torque motors; typical is: NEMA-23 50 in-oz, 6,000 RPM 200W (1/4 ~ 1/3 HP) NEMA-34 150 in-oz, 4,500 RPM 500W (2/3 HP) You trade in unneeded RPM for badly needed torque by gearing the motor down. Say you have a NEMA-23 motor with the above specs: Router thrust = Pinion torque / Pinion radius = 50 / 0.16 = 314 oz = 20lbs. The router's "push" is only 20lbs continuous. You apply more load than that and you will burn the motor down. Router Speed = Motor RPM * Pinion Circumference = 6,000 * 1 = 6,000 IPM. 6,000 inches per minute is kinda fast, maybe 1,200 IPM is more practical. You get that by gearing the motor down 5:1 which now gives you 5 times more push, 100 lbs instead of 20 lbs. Mariss |
| "Router thrust = Pinion torque / Pinion radius = 50 / 0.16 = 314 oz = 20lbs." Are you calculating this when pinion is directly conected to the motor? Because there is an 1:3 reduction from motor to pinion. Actually I checked twice and you already included it? 0.16 is .5/3. Sorry for that. |
| G320 and Encoder compatability? | gavztheouch | Gecko Drives | 2 | 06-02-2009 08:31 AM |
| encoder cpr ?? g320 | chrisw765 | Gecko Drives | 1 | 03-08-2009 11:54 PM |
| UNKNOWN ENCODER & G320. | salman | Gecko Drives | 0 | 01-02-2008 10:45 AM |
| encoder question for G320 | CNC Darren | Gecko Drives | 7 | 11-15-2007 12:14 PM |
| encoder question for use on G320 | Runner4404spd | Gecko Drives | 0 | 12-08-2005 10:32 PM |
