Old 11-03-2010, 04:10 PM
GregS is on a distinguished road
Buying advice
I have a desktop mill that needs a new driver board.
I am looking at the G540, but have some questions with the current PSU and steppers.
Motors: (4) LIN 4218l-01-10 (2A/Phase 2.6mH/Phase)
Note: X-Axis requires 2 motors for a total of 4 motors.
PSU: MEAN WELL PSP-600-27 (27V 22Amp)
Is the current PSU too much for the steppers/g540?
Any reservations against this setup? Anything is replaceable, however the Nema 17 size must remain the same.
Old 11-07-2010, 08:44 PM
MrWild is on a distinguished road
The steppers and G540 will only use as much amps as they need. You could have a 27volt, 200amp supply and the Gecko and motors would still only use as much as they need. Like your common house light bulb. There is a 20 amp capability, but it uses ~1/10 of an amp to light.
If you are looking for an excuse to buy a new power supply though, I'd buy one with a lot more volts. The 48v. 7.3A ones are ideal. More volts means a slower power drop off as the motor spins faster. You WILL notice a difference with more volts.
Buying CNC mill need advice ready961 General Metal Working Machines 2 11-14-2008 07:10 PM
New Machine Build- buying torchmate 1, but need advice... nascarstewartfa CNC Plasma and Waterjet Machines 0 10-26-2008 12:28 PM
Buying a used lathe; advice please! DrStein99 General Metal Working Machines 0 01-10-2008 08:14 AM
Buying a X3, need some advice dneisler Benchtop Machines 2 06-05-2007 07:41 PM
