Results 1 to 2 of 2
Thread: G540 and E-Stop
    Jul 2010
    G540 and E-Stop
    Being an electronics novice I bought a pre-built, pre-wired CNC Controller box with a Gecko G540 from Keling. Nothing worked and the Fault light would not go off until I pushed in the E-Stop button, then everything works fine. When I opened up the case put a meter on the switch I discovered it's wired so it's normally open when the button is in the out position and closed when the button is in the in, latched position. Is this backwards? Shouldn't it be wired normally closed?
    Jul 2007
    It sounds like your switch is mis-wired. The e-stop circuit should be closed that way a wire break will trigger an e-stop rather than disable the e-stop circuit.
    If they are using the same switch I bought from them, it is a simple matter to rewire it to NC. It sounds like someone made a mistake assembling it.
    bob
  1. G540 E-stop and Mach3
    By Astroguy in forum Gecko Drives
    Last Post: 02-02-2012, 11:10 PM
  2. New Machine Build- EMC2 E-stop parallel port pinout and E-stop loop
    By GreenLead in forum LinuxCNC (formerly EMC2)
    Last Post: 08-03-2010, 01:05 PM
  3. G540 emergency stop circuits
    By tooManyHobbies in forum Gecko Drives
    Last Post: 05-26-2010, 02:51 PM
  4. G540 e-stop question
    By vintageracer in forum Gecko Drives
    Last Post: 01-04-2010, 05:45 PM
  5. G540 Low voltage for E-stop and limits?
    By MrWild in forum Gecko Drives
    Last Post: 10-14-2008, 05:28 AM
