| Have you gotten any of them to work? Are they getting to hot? When you say "blown up", what exactly happens to them. I think the fuse just protects against incorrect power supply wiring. What voltage are you using? The manual states that greater than 50V can damage the drive.
I walked in to cut a plane, turned on th epower and flipped the estop so I could start mach3, nothing. I have tested my PS 48VDC at 12.5A constant. I reckon blew up means that it does not work anymore, there was not an actual explosion, nor was the smoke let out, that I could see. I took out the fuse and tested the resistance and it tested fine. I put a new fuse in it just to be on the safe side, but nothing.... I have one in the post back to Gecko, and now one on my desk going back monday. David |
| I'd seriously look at your wiring.
You know, that may be a possibility, as I have motors that came Pre-engineered with db9 connectors on them and the resistor pre-soldered in. However, I have in my infinite wisdome and abrupt clumsiniess (SP) tripped over them and pulled the little pins out of the connectors a few times. I bought some Ez-g540 connectors off the internet last night, I am going to redo the db9 connectors, and finish my e-chain so I don't kick the wires out anymore David |
#10
| I would also recommend checking your wiring. Generally the things that will take one out are repeated shorts between output pins or disconnecting the motor while powered up. Another way to kill one might be to put a switch between the power supply and G540 (only switch the AC side not DC). Thanks for the kind words on the EZ-G540. I'm glad folks like them. Unfortunately CNC Zone disables links to commercial sites that do not advertise here (I'm not griping, just explaining.) If you Google EZ-G540 you'll find them or go to soigeneris dot com.
__________________ Jeff Birt |
#11
I have it whupped now, Dan made me a box, and brit mailed my ezconnectors yesterday. all I should have to do is turn it on, hopefully it won't be grounded against my shop table. I thought I had a welder going there for a second. Soon I may have to sell it for scrap ;P |
#12
I gotta give PROPS to the folks over at Gecko, they fixed both of them and didn't charge me a dime. I hope ow that I have the drive enclosed in a case, with all the wires and relays and thing hooked up right, thanks to Dan at Camtronics. Hopefully I can now get past the "Build" phase of theis thing and get on to the fun stuff!! |
| where can i get these fuses | mycoolbeard | General Metal Working Machines | 7 | 07-17-2009 04:16 AM |
| Blowing fuses | kaderick | General Electronics Discussion | 2 | 12-05-2006 11:34 AM |
| Blown Fuses | sommerjd | General Electronics Discussion | 6 | 10-01-2006 04:02 AM |
| Blowing the fuses | rocks101 | Hobbycnc (Products) | 2 | 02-26-2005 03:00 AM |
| Confused about fuses. | FLUTE HEAD | General Electronics Discussion | 9 | 09-24-2004 11:54 PM |
