Old 10-12-2010, 03:34 PM
GtownHigh is on a distinguished road
Exclamation Restoring an old machine
Our school, germanntown high of wisconsin, got an old CNC machine donated to us. It is full sized and has an extremely antiquated computer inside (8 KB of ram!). The tape drive was erased after the battery failed so we went to work updating it to use geckos. We have a simple plan of attatching the gecko 320x to the servos and running it via paralell. We have used the programs: EMC2, MACH3, KCAM 4, and other programs that we experimented with. We cannot get voltage to come from the gecko, out to the motors! We have 0VDC out and 36 in! We have everything correctly configured and have beenw orking on it on and off for over a year now. The computer is sending voltage out, the paralell cable is good, the motors work and we tried 3 different geckos! If anybody has any suggestions i am all ears. We would really appreciate some help.
thanks in advance
Old 10-12-2010, 05:18 PM
ger21's Avatar
Call Gecko.
What happens when you apply power to the Geckos? Are the motors locked up, or do they spin freely? Are you using a breakout board?
Old 10-12-2010, 06:11 PM
ger21 thanks for responding
when we apply power (i assume you mean the power for the motors) to the correct terminals on the gecko...nothing happens, no voltage out the other side either, however i put some voltage on the motors themselves and they turn. Unfortunately we do not have a breakout board but i test the paralell cable with a multimeter and voltage comes out when i jog it. I emailed gecko but the guy stopped responding.
Old 10-12-2010, 06:23 PM
ger21's Avatar
Do you have proper encoders connected?
The manual says to test your step and direction signals before connecting the motors, did you do this?
You really need to call them. They're very helpful on the phone.
Old 10-12-2010, 06:34 PM
I will definitely call them, and yes we did connect step and direction first, none of it works at any step. When i call gecko, will not having the motor specs matter? The guy i emailed asked for them and we cannot find them anywhere, there is no plaque or anything.
Thanks for your help
Old 10-12-2010, 07:59 PM
Al_The_Man's Avatar
What is the working area size of the machine just to get an idea of what the motor size maybe, also do you have info/make on the original drives?
Do you know the resolution of the encoders and how do you have them fed, 5v supply etc.
Old 10-12-2010, 09:34 PM
morestuff is on a distinguished road
no output from Gecko servo drive
Gecko servo drivers power up in an inactive state. You must connect the ERR/RES terminal to the ENC+5 terminal, at least momentarily, in order to enable the drive. Check your user manual for details.
Steve Stallings
PMDX.COM - Products for CNC and motion control applications
Old 10-13-2010, 02:56 PM
The working area is about 4 feet by 2 feet, we have the encoder fed through the 5v supply (ac adapter) and I could not find the resolution of the encoder, though we do have the specs..Also what is gecko number, the one on the instructions has been disconnected
Old 10-13-2010, 06:35 PM
ger21's Avatar
Geckodrive - Quality American Made Stepper and Servo Motor Controls
Tags
emc2, gecko, gecko 320x, geckodrive, kcam
Need Help!- Restoring System parameters with A.top mfugs Okuma 4 10-24-2009 01:53 PM
Restoring Old Atlas Lathe creative_mind General Metal Working Machines 9 06-06-2009 08:33 PM
Restoring a BP series II CNC unterhaus Vertical Mill, Lathe Project Log 16 12-04-2007 01:07 PM
Restoring an old Atlas lathe sanddrag Mini Lathe 6 03-18-2006 10:43 PM
CNC Madness (Restoring old parts) samualt CNCzone Club House 2 06-19-2004 09:04 PM
