| Hello everyone, I would like to try a 6 axis setup, 2x Nema34 1800 Oz/In Stepper Motors, and 4x Nema34 1200 oz/in stepper motors, all from keling, as well as 6 Geckodrives. There is not really an application for such set up, just being curious how I should wire it up. The Rectifiers i'm using is a Bulky Block 35A Rectifier, where i guess it is good enough to supply up to 3 motors per Rectifier. If I use another Rectifier to cater the another 3 motors, is it really recommended? What i'm concerned about is each rectifier made has its tolerance where the AC to DC conversion may not be as accurate as AC/0.707 = DC, which will result in DIFFERENT MOTOR PERFORMANCE, in terms of Speed (V) and Torque(A). Does it really matter? or not? Thank you guys. Charles
__________________ "I will not let you regret knowing me." |
The characteristics of most silicon rectifiers is voltage across the junction will increase with current, from av. of .6v min I to 1.2v at max. rated I. Don't forget there is two in series in a bridge configuration. Consult the manufacturers spec for the actual numbers. Al.
| Newbie- Rectifier Size - can it be too big? | MattTheNoob | General Electronics Discussion | 2 | 04-21-2009 10:25 AM |
| Disable feature on Geckodrives | technosteve | DIY-CNC Router Table Machines | 4 | 01-17-2009 10:00 PM |
| What Servo Motors to Buy to be Controlled by Geckodrives? | waleed alhadidi | Gecko Drives | 0 | 09-16-2008 11:39 PM |
| bridge rectifier | osdhillon | General Electronics Discussion | 4 | 12-30-2005 09:24 AM |
| What is wrong with this freaking rectifier | Noah | General Electronics Discussion | 31 | 05-09-2004 08:47 PM |
