Old 09-27-2010, 01:57 AM
Brenck is on a distinguished road
G201x Trimpot adjustment missing information
Hi all,
I recently started to use G201x but still did not adjust the trimpot to avoid slow speed vibration.
The problem is that on the G201x manual there is no info about it.
On a G203v manual says you are suppose to put the motor to rotate 1/2 turns per second and adjust the trimpot until you have it smooth.
But on a regular G201 manual says you are suppose to put the motor to run 1/4 turns per second and then adjust the trimpot until you have it smooth.
And on a G540 manual says you are suppose to put the motor to run 2 turns per second and then adjust the trimpot until you have it smooth.
What about the G201x do I use 1/2 turns per second? or 1/4? or 2 ? Or other?
Thank you,
Gustavo
Tags
adjust, adjustment, g201x, trimpot, vibration
G201X power switch crochambeau Gecko Drives 5 04-18-2010 10:22 AM
G201X is now for sale! CoAMarcus Gecko Drives 1 02-14-2010 07:16 AM
Preliminary G201X Manual CoAMarcus Gecko Drives 2 01-20-2010 01:50 PM
G201X Mariss Freimanis Product Announcements & Manufacturer News 0 11-13-2009 05:05 PM
Next up, the G201X Mariss Freimanis Gecko Drives 11 08-17-2008 09:26 PM
