Results 1 to 5 of 5
Thread: G201X can only turn the motor to one direction.
    Jan 2006
    Thailand
    Hello!
    I've been using 3 sets of the G201X for a few months, and last week one of them is having a problem. Regardless of the direction being sent, it turns the motor to only one direction. Is there anything that I can do to solve this problem or should I just send the G201X back to Gecko? I think that they're still under the warranty
    Wachara C.
    H.O
    H.O is offline
    Jul 2007
    Sweden
    Sounds like the opto-isolator might be shot. Try swapping the drive with a known working unit just to verify that it indeed IS the drive and not something
    You should be able to replace the opto-isolator if you're careful. If you're not sure about it you'd be better off just sending it back to Geckodrive to get it repaired.
    /Henrik.
    Jan 2006
    Thailand
    Quote Originally Posted by H.O View Post
    /Henrik.
    Hi H.O,
    Thanks for your reply. I'm not sure which chip is the opto-isolator. Is it the one in a socket. There is only one chip that can take out and replace easily as far as I can see.
    Wachara C.
    H.O
    H.O is offline
    Jul 2007
    Sweden
    My G210's are 9+ years old and have the opto-isolator in a socket, sounds like yours does as well. If it's an 8-pin device and it says HCPL-2631, HCPL-2531 or something like it then that is it.
    If you have verified that it IS the drive then you can try swapping opto-isolator chips between a working and the non working drive. That way you'll verify if the opto-isolator is bad. Be careful when you extract and insert them so you don't bend any of its legs etc.
    If it still doesn't work it might be the little resistor in series with the LED inside the isolator. Is there any chance you might have connected a voltage higher than 5V to the direction input? That can kill the isolator and/or the series resistor.
    Don't mess with it if you don't feel comfortable, send it back and they will repair it - if it's reparable.
    /Henrik.
    Jan 2006
    Thailand
    Hi H.O
    Thank you very much for your advice. I've confirmed that the fault is actually from the drive. I don't think that I will be able to repair it. I'll just send it back to Gecko for a repair then. Thanks again for taking your time to help me.
    Wachara C.
    1. Need help with motor direction
      By marzetti in forum Automation Technology Products
      Last Post: 11-30-2009, 09:59 PM
    2. G201X
      By Mariss Freimanis in forum Product and Manufacturer Announcements
      Last Post: 11-13-2009, 06:05 PM
    3. Next up, the G201X
      By Mariss Freimanis in forum Gecko Drives
      Last Post: 08-17-2008, 10:26 PM
    4. Motor Direction
      By Ken Bond in forum Phase Converters and VFD
      Last Post: 11-20-2007, 07:22 AM
    5. stepper motors turn only one direction
      By Mike Boarman in forum General Electronics Discussion
      Last Post: 11-24-2006, 05:43 PM
