Old 09-01-2010, 04:27 PM
Brian Corwin is on a distinguished road
Driver to adjust the g540 trim pot?
How are people turning the trim pots on the g540? Everyone says use a non conductive screwdriver, yet the only one I found (ceramic driver) on amazon doesnt reach deep enough? I have tried toothpicks, whittling down chopsticks, etc and cant seem to get it? Can/should I disassemble the 540?
Any advice / links to drivers that actually work would be much appreciated.
B
Old 09-01-2010, 04:57 PM
MrWild is on a distinguished road
Who is everyone? You're the first o0ne Ive heard it from. I used a HF jewelers screwdriver. It has a steel tip. No problems at all and as I'm deaf I had a girl do it for me while I jogged the motors. As long as you direct the screwdriver perpendicularly through the hole, it goes right into the trim pot.
Old 09-01-2010, 05:48 PM
Crevice Reamer's Avatar
Crevice Reamer is on a distinguished road
Yes, you can use a normal screwdriver if you are careful to not touch anything else. You can also put some heat shrink tubing on all but the tip.
CR.
http://crevicereamer.com
Too many PMs. Email me to my name plus At A O L dot com.
G540 Trim... when do we adjust and how dex918 Gecko Drives 26 11-01-2011 02:08 AM
Problem- Old machine need new steppers and driver, G540 with keling kit in mind. giveinfo DIY-CNC Router Table Machines 8 08-08-2010 08:03 PM
g540 driver ghostlx Gecko Drives 7 04-19-2010 07:47 PM
g540 trim pot ?? chrisw765 Gecko Drives 1 06-08-2009 03:47 AM
Trim john_mccarron EdgeCam 3 11-27-2007 06:42 PM
