From thread on 5/5/2010: http://www.cnczone.com/forums/showthread.php?t=104578
Can this info be added to the FAQ ? The capacitor wiring is straight forward, but could someone describe further the rectifier diode ? What would be an example of a proper diode part number/rating ? Should it just be in line on the +VDC output before the capacitor ? I've also come across mention of a drain resistor for the capacitor. How would it wire in, and what would be a likely ohm/wattage for it ? |
| We can add that to the FAQ. A bridge rectifier that I recently used to build a 48VDC power supply is a GBPC3504 that I got from Digi-Key. Here is a link to the specific component: http://search.digikey.com/scripts/Dk...504-E4/51GI-ND You wire a bridge rectifier into the power supply like it is shown in this diagram: http://geckodrive.com/upload/2793powersupply.gif A drain resistor is not needed for the power supply as the motor controls act as a suitable drain. Marcus |
| Thanks for the reply Marcus. I'm still not sure about the diode. You referenced a bridge rectifier to change AC to DC, but my question and reference to the posting by Mariss is for the use of a switching power supply which is already outputting DC. What type of diode would we use, in line, I guess ? As for the drain resistor, thanks again, that clears that up. Rick |
| Since the output of the PS is already DC use a straight rectifier such as this: http://search.digikey.com/scripts/Dk...name=D4020L-ND Put the diode in-line with the positive side of the PS, before the 10,000 uf cap.
__________________ Bob "Bad decisions make good stories." Last edited by bobsch; 08-20-2010 at 05:42 PM. |
| Switching power supplies and DC servo motors | eldata | General Electronics Discussion | 7 | 12-08-2009 07:46 PM |
| Geckos w/ Switching Power Supply? | mrosso | Gecko Drives | 4 | 11-04-2009 12:44 PM |
| Problem- 20A Switching Power Supply | droddis | Hobbycnc (Products) | 10 | 03-14-2008 12:00 AM |
| More power from switching power supply | R.thayer | General Electronics Discussion | 4 | 03-10-2007 07:03 PM |
| Switching Power Supply | CharlieM | Stepper Motors and Drives | 3 | 05-08-2006 08:17 AM |
